I have been working on the rear suspension, of my 63 SWC, and messed up one of the washers that is staked to the trailing arm. This was the last of the four I installed. (I am not quite sure why the hole is so much bigger than the washer) So I ordered another. The mistake I made is I used a different vendor with out thinking of the consequences. After waiting 6 days for my order the washers arrived. I was astounded to find the washers had a different finish than the first set. The Volunteer Vette washers were zinc coated and the Paragon washers were phosphate. I have a 1963 and I doubt GM changed the finish on the washers over time but I could be incorrect. So which ones do I use? I could pull the three zinc washers I have installed and use the replacement Phosphate washers or order a matching one from the original vendor.
Rick
Rick
