C2 headlights - NCRS Discussion Boards
C2 headlights
+ More Options
Posts
  • Michael M.
    Infrequent User
    • January 9, 2017
    • 4
    C2 headlights
    Question, C2 headlight buckets. Are there any adjustments side to side after the buckets are installed. Thanks Mike
  • Russ S.
    • April 30, 1982
    • 2163
    Re: C2 headlights
    Yes there is.
    The one side has a locking collar with a set screw in it that can be adjusted. The collar allows the bucket to be adjusted one direction. I forget at the moment what keeps the bucket from moving back the other direction
    • Jim D.
      • 2885
      Re: C2 headlights
      The "Y" stop on the inside adjusts the outward bucket movement (and the open and closed positions). The collar Russ referred to adjusts the inward movement.
      • Russ S.
        • April 30, 1982
        • 2163
        Re: C2 headlights
        Thanks Jim for the memory jog.
