M20 Muncie Rebuilding Services - NCRS Discussion Boards
  • David M.
    • September 30, 2004
    • 525
    Hello,
    Can anyone recommend a good reputable, fair priced, M20 rebuild shop or service? I have been getting some rather expensive quotes locally. I can do this myself but don't have the time. I think all it will need is synchros. It shifts into gear with too much effort I went through it about 10K ago but stupidly did not install new synchros as they inspected fine...at that time. Shifter and rods are fine.
    Im close to Syracuse New York.
    Dave
  • Jim T.
    • March 1, 1993
    • 5351
    Re: M20 Muncie Rebuilding Services
    Suggestion, check out the NCRS Driveline. There are some rebuilders that have many 4-speeds for sale.
    • Larry M.
      • January 1, 1992
      • 2700
      Recommend D&L Transmissions in New York. http://www.dandltransmission.com
      Larry
      • Joseph S.
        National Judging Chairman
        • March 1, 1985
        • 886
        I Second D&L
        • David M.
          • 525
          Thanks all. Keep the suggestions coming. I like to shop around. I'll look up D&L.
          • Larry M.
            • January 1, 1992
            • 2700
            I am not certain you will find a better and more knowledgeable shop...........regardless of location.
            Larry
            • Gary B.
              • February 1, 1997
              • 7046
              David,
              You can also try:
              Hartnett Ed 4 Speeds
              (610) 623-9381
              242 Pembroke Ave, Lansdowne, PA 19050
              Gary
              • Brian T.
                • September 30, 1990
                • 190
                Another positive vote for Larry at D&L. Used him many times.
                • Bill L.
                  • February 1, 2004
                  • 1403
                  I used Jody's Transmissions for my M20. Great guy, great work. He even let me help with the rebuild on a cold Sunday. I washed and cleaned up everything and he explained everything as he went.
                  He is in PA.
                  Kind Regards,
                  Bill
                  • Brian M.
                    • February 1, 1997
                    • 1840
                    Make that 3 for D & L.
                    • Frank D.
                      • December 27, 2007
                      • 2703
                      D&L is first rate. Manchester Muncies has done some work for me and they were excellent as well...very reasonable...
                      • David M.
                        • 525
                        Excellent thanks guys for the replys.
