c-4 rack and pinion - NCRS Discussion Boards
c-4 rack and pinion
  • Mike M.
    • May 31, 1974
    • 8397
    c-4 rack and pinion
    the pair of hoses from the power steering pump to the rack and pinion mount inboard on one, and outboard on the other hose. i'm installing a 86 front suspension in my daughter's 50 chevy convertible and need to know whether the inboard or outboard location is for the high pressure hose. thanks, mike
  • Kenneth P.
    • November 17, 2015
    • 151
    Re: c-4 rack and pinion
    Here's a drawing I found that may answer your question. According to the article this should cover 84 to 87 C4.
    • Mike M.
      • May 31, 1974
      • 8397
      thanks ken. your illustration indicates the high press line runs to the outboard location on the rack and pinion.. mike
      • David H.
        • June 30, 2001
        • 1539
        Mike,
        Another image with pressure line identified.
        Dave
        • Mike M.
          • May 31, 1974
          • 8397
          this illustration must be a 88-up c-4 as the hoses here run front to rear, whereas the 87 rack's hoses run nearly left to right. thanks again, mike
