C1 Window glass track guide, screws - NCRS Discussion Boards
  • Ed P.
    • August 10, 2014
    • 89
    ok also know as guide rail where the rolls ride in.
    This channel is attached to the lower sash window frame, by 4 screws, 8 per car.
    My question is. Where can i get the 8 screws? I stripped a few taken them out.
    PLEASE HELP
    All you guys are very helpful.
    EDD
  • Dan B.
    • July 13, 2011
    • 545
    Re: C1 Window glass track guide, screws
    Ed, these are just flat head phillips machine screws, you should be able to find them at a local hardware store. The vendors do sell them I believe as well. IIRC they are 8/32 x 3/8 but double check that with one of the old ones. Dan
    • Dan D.
      • November 5, 2008
      • 1323
      Believe that is correct size - but don't remember if they are 82* or 100*. They also have a captivated star washer that you are not going to find at any hardware store. So if you want to retain the locking feature you will have to Loctite them
      -Dan-
      • Ed P.
        • August 10, 2014
        • 89
        Dan thank u, thank u very much.
        • Mike E.
          • February 28, 1975
          • 5140
          At the hardware store, buy some #8 internal tooth star washers. Install one on each screw. As you carefully tighten the screw, the lock washer will be properly bowed.
          • Dan B.
            • July 13, 2011
            • 545
            You can also place a locking washer over the inverted screw and carefully form it with a small hammer in the vise and it will look and function the same. Thumbs UP !
            • Ed P.
              • August 10, 2014
              • 89
              thank you again Dan and Mike
              • Ed P.
                • August 10, 2014
                • 89
                I got the screws and star washers today at Lowes.
