Caliper halves keep leaking! - NCRS Discussion Boards
+ More Options
Posts
  • Gary S.
    • July 31, 1992
    • 1633
    I just had an interesting ride in that I almost wrecked my 1972. After a complete rebuild of all four calipers I had difficulty getting the right front caliper halves to seal. I rebuilt them twice including using new O rings (talking about the little 1/2" O ring used to seal the halves) because the first time I couldn't get the halves to stop leaking. After successfully bleeding them and a couple of minor test drives I took the 72 out for a couple of local errands. Approaching a stop sign, the pedal went to the floor but, luckily, the rears were working fine. I limped home and brake fluid is seeping out of the bottom of the caliper at the O ring. Is there such a thing as a caliper warping such that it won't seal or is the such a thing as an over sized O ring? I am not new to rebuilding these types of calipers but this one has me stumped.
    They have been previously sleeved with SS and have been working well enough before I decided to "fix" them.
    • 43263
    Re: Caliper halves keep leaking!
    Gary------
    I've never heard of this. I realize that you did this twice but are you sure the o-ring did not become dislodged prior to your mating of the caliper halves? I would not think that an over-sized o-ring would be a problem. An undersized one might be, though. By undersize, I'm referring to cross section and not OD/ID. As long as the o-ring fits into the machined relief in the casting half, the latter should be fine.
    • Gary S.
      • July 31, 1992
      • 1633
      I, too, have never seen this nor experienced it. I am going to put a straight edge on both halves to see if there is some unseen issue with them. I am doubly certain that the O rings are still there and properly seated but I am going to take this one caliper apart AGAIN. This is driving me crazy. Perhaps the O ring was defective (both of them?) and came from a supplier with QC issues?
      Do you or anyone else know if this O ring is available without going through one of the usual Corvette specialty shops. That is, is this a common size and sold at Advance Auto, Auto Zone, Kellys or somebody like that? I had hoped to be driving this car soon.
      • Gary S.
        • July 31, 1992
        • 1633
        Confession time! I took the caliper off thinking, boy those halves seem to have a gap in them. Put my socket on the bolt and it spun freely in my hand!!!!! How on earth that happened I don't know but we'll chalk up one ruined set of new Delco 17D8 pads to a lesson learned. Ok, I have my flame retardant suit on - fire away!
        I am humbled at making such a stupid and avoidable mistake. I even thought I went around and checked all of my work. This was the one caliper that leaked after a rebuild so I can only assume that I was in a hurry since this was the last thing to be done after its hibernation.
        Sorry for the wasted time, gents.
        Gary
        • Leif A.
          • August 31, 1997
          • 3648
          Gary
          Yeah, because none of us have ever done anything like that Glad you found the answer and addressed before a real problem presented itself...like-an-accident!!
          Leif
          • Gary S.
            • July 31, 1992
            • 1633
            Leif,
            When I came up to the stop sign at 35 mph and the brake pedal went to the floor I almost did. I did a quick pump (thinking maybe Master Cylinder - it couldn't be the brakes themselves) and got enough pedal to lock up the rears, with a minor fish tail. Limped home and now I am checking my work.
            What amazes me is that this passed a "pump/release" two person bleed and two minor test drives with heavy braking. Not a drop anywhere until I was out in the neighborhood.
            New pads on order. This is getting pricey.
            Gary
            • Paul Y.
              • September 30, 1982
              • 570
              Glad you are safe Gary. Pads are cheap compared to fiberglass repair or human body damage.
              It's a good life!
                • 43263
                Gary
                Gary------
                I was going to ask you if you had the caliper half clamp bolts properly torqued but I figured no way would you have that wrong.
                By the way, the front caliper half clamp bolts are torqued to 130 lb/ft. This is the highest torque spec of any fastener on a Corvette.
                • Gary S.
                  • July 31, 1992
                  • 1633
                  Joe,
                  of course I checked the bolts because NOBODY forgets something as simple as that. (Looking for an emoji of idiot slapping his forhead.) Huge duh on me but I serviced and I learned.
                  • Richard M.
                    Super Moderator
                    • August 31, 1988
                    • 11356
                    Gary, Glad you're okay. Don't beat yourself up.... things happen. We're all the same we just have different names.
                    BTW, I had a caliper that drove me crazy once. I too thought it was at the 2 halves joint at the bottom. Retorqued, okay and figured it'd have to come apart. It was actually a leaky bleeder port due to bad machined surface. It would slowly drain down and drip at the bottom joint.
                    I was going to mention it when reading your posts but you found the loose bolt.
                    When I do a chassis restoration or brakes, steering, or anything critical, I have a few fail-safes I use. If any fastener is not torqued, I put a piece of colored masking tape on the bolt or nut. At a glance I can see if I missed something. Comes in handy. On non-judged type car tasks, I'll use a marking crayon and put a dab on every fastener after it's torqued.
                    Rich
                    PS Joe, What about the Pitman Arm Nut to steering box shaft? Isn't that around 150 lbs/ft?
                    • Gary S.
                      • July 31, 1992
                      • 1633
                      I too have methods for ensuring that bolts are checked and double checked. I certainly failed on this one. Your technique/reminder is better than my system.
                        • 11689
                        Good thing you drove the planes, and didn't work on them.
                        • Gary S.
                          • July 31, 1992
                          • 1633
                          Hey. Hey. That ain't fair. They never asked me to work on the airplane (well, once in Saudi Arabia in 1976 I helped change an engine - 110 degrees, no proper lift or hoist and only basic tools. Six hours but we did it and I didn't get to torque anything.)
                            • 15626
                            We never worried about leaks on the F106. The term was: "Normal seepage." Of course I don't think Convair makes flying machines any more, at least I hope not.
                            • Gary S.
                              • July 31, 1992
                              • 1633
                              While I don't know anything about its reliability or flying personalities, it is one gorgeous airplane.
                              Gary
