69 windshield washer hoses - NCRS Discussion Boards
  • Dennis W.
    • July 27, 2011
    • 63
    I have a few questions about hose sizes (ID, OD) for the windshield washer hoses. Any comments or advice would also be appreciated.
    #1 - I measure the hoses from the anti-drip valve output nipple to the "T" and the hose to driver wiper arm as 3/16 ID & 3/8 OD.
    #2 - I measure the hose to the passenger wiper arm as 3/16 ID and 5/16 OD (thinner wall than #1). I believe this hose is original because it has black sealant on it at the wiper end like several areas in the plenum.
    #3 - The hoses from the pump output to the the anti-drip valve were missing but I want to reconstitute the whole system.
    I purchased a hose kit from Paragon. However,
    #4 - The various lengths of hoses are the same. I understand that Doc Rebuild's are not the same.
    #5 - The kit I purchased, does not include the "T" mentioned in #1 above and mine is broken. The base/inlet of my "T" is larger than the two outputs/arms and it is solid black in color. Does anyone have a source for these?
    #5 - Since the pump to anti-drip valve hoses are missing altogether, I also need a "T" or "y" to combine the pump output from the two nipples to the one inlet of the anti-drip valve. Am I correct about the "T" or "y" and does anyone have a source.
    I have looked in my AIM and researched this site and found a lot of good information but not these answers. Many thanks to those who respond.
    Dennis Wright
    '69 White/Red Coupe
    L46/M20/PS/PB/AC
    404/388-7686 (c)
  • Geoff C.
    • May 31, 1979
    • 1613
    Re: 69 windshield washer hoses
    Perhaps you should contact the source of your purchase & ask them what is what.
    I read your message & I'm confused also.
    • Dennis W.
      • July 27, 2011
      • 63
      Sorry, in #4 I meant to say, "the various lengths of hoses are the same size, ID & OD."
      Thanks again.
      Dennis Wright
      '69 White/Red Coupe
      L46/M20/PS/PB/AC
      404/388-7686 (c)
