67 Convertible carpet judging - NCRS Discussion Boards
  • Kerry A.
    • August 31, 2004
    • 155
    I'm in the process of restoring the entire interior of my 67 Convertible. What I'm confused about is the carpet underlayment. Unless I overlooked it, from what I've found in the judging manual the underlayment isn't discussed. Is the jute/rubber underlayment all that is required? Thank you in advance for your help.
  • Keith B.
    • September 15, 2014
    • 1604
    Re: 67 Covertible carpet judging
    You can't judge what you can't see
    • Gene M.
      • April 1, 1985
      • 4233
      Jute backing was original but as stated you can't judge what ya can't see. I would suggest something less apt to absorb moisture and or order. The more modern under matts are far better if you conceal there use.
      • James B.
        • March 1, 1985
        • 217
        Besides judging by sight, can something also be judged by touch (e.g. too soft, too hard or too spongy underlayment being detected by lightly pressing the carpet)?
        • Gene M.
          • April 1, 1985
          • 4233
          I would suggest the under layment below the carpet will not be densernable "feel" from original to modern optional material.
          • Richard M.
            Super Moderator
            • August 31, 1988
            • 11363
            Gene, If it smells bad, it's original. I think the judges with crisp noses could tell the difference.
            • Kerry A.
              • August 31, 2004
              • 155
              Gene, Is there a typical product you would recommend?
              • Gene M.
                • April 1, 1985
                • 4233
                Kerry
                I had good results with Nicole 80Milsound deadened sold by Amazon. It's similar to Duramat. Thinner with a sticky backing.
                I see Amazon is out of stock. But sure the other brands that are butyl are pretty much the same.
                • Gene M.
                  • April 1, 1985
                  • 4233
                  Rich,
                  I'm sure most everyone would avoid reusing stinky padding in the Corvette..............
