Ground strap location, '65 with side exhaust - NCRS Discussion Boards
  • Michael G.
    • September 10, 2015
    • 32
    There is supposed to be a ground strap connected somewhere on the sill plate, one end with a screw and the other with a clip. I can't figure out the connection point. Any suggestions or AIM page references are greatly appreciated.
  • Don H.
    Moderator
    • June 16, 2009
    • 2284
    Re: Ground strap location, '65 with side exhaust
    UPC U69 Sheet A4 (pg E369)
    Upper right illustration.
    • Michael G.
      • 32
      Ok, that's the picture that came with the set of straps. Problem is, I can't figure out what I'm looking at. Is that at the forward end of the driver's side doorsill?
      • Jim D.
        • 2885
        Here's a pic. of the strap with the body removed. The clip at the end of the strap goes onto the birdcage sill plate. It's the same with or without side exhaust.
        • Michael G.
          • 32
          Thanks Jim. I'll get up underneath and see if I can see the hole in the forward body mount. That is the driver's side, correct?
          So I guess the difference in grounding on N14 cars is that there's no strap where the exhaust clamp would be, at the crossmember?
          • Jim D.
            • 2885
            Yes on both questions.
            • Michael G.
              • 32
              Thanks Don and Jim - with your help I got the little devil installed.
