1954 spark plugs - NCRS Discussion Boards
1954 spark plugs
  • Al E.
    • September 5, 2011
    • 313
    1954 spark plugs
    Does anyone know the original plugs for the 54 are judged? if so which ones are they?
  • Chris S.
    • January 1, 2000
    • 1067
    Re: 1954 spark plugs
    The plus are listed in the JM
    smooth AC #44-5 with the Corolox emblem up to mid 54 production
    after mid 54 the Corolox emblem disappeared
    They are a fat body type plug
    1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
    Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
    1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
    1957 Corvette - FI 3 sp - Black and Silver
    • Al E.
      • September 5, 2011
      • 313
      Thanks Chris.do the judge pull the cover off to inspect the plugs?
      • Mike M.
        • May 31, 1974
        • 8382
        u will be asked to remove the upper half of the ignition shielding before judging begins. mike
        • Chris S.
          • January 1, 2000
          • 1067
          Al the upper cover is removed for judging - as they also inspect the coil, wires, dist cap, and rotor and distributor base plate. Most people just leave it off as its a PITA....
          • Al E.
            • September 5, 2011
            • 313
            Thanks guys...good to know. I was hoping that wouldn't happen. I just bought some clorox plugs 1953 dated box.. but I have another set that doesn't have clorox on it..or a date but look the same. . not sure if this is the same as the bleach company...but which set do the judges want.
            • Chris S.
              • January 1, 2000
              • 1067
              was vin is your car ?
              • Al E.
                • September 5, 2011
                • 313
                #4403 with the 2 pot air filters
                • Chris S.
                  • January 1, 2000
                  • 1067
                  I would the non emblem ones - late car.
                  • Mark W.
                    Infrequent User
                    • May 15, 2007
                    • 15
                    The spark plugs are smooth ribbed and are 44-5 and have coralax on the side too.
                    Mark Wiley
