Lacquer touch up paint - NCRS Discussion Boards
  • David C.
    • June 30, 2006
    • 126
    Hi, my 1973 has single stage paint much of which I believe is the original lacquer in dark blue metallic. I have a couple small touch ups to do, including a small chip I just caused at the door edge.
    Most of the touch up paint I have seen advertised is base coat / clear coat. Does anyone know a source for specifically lacquer touch up paint?
  • Michael J.
    • January 27, 2009
    • 7166
    Re: Lacquer touch up paint
    I don't know of any lacquer touch-up paint, but I have used this company for my '64s and '66s with single stage lacquer paints for small touchups and they look and match great, I buy only the base coat color:
    Restore your car's original paint with automotive paint that's an exact match for your car's color. Our touch-up paint is high quality to deliver professional results to every paint job. at AutomotiveTouchup
    • David W.
      • January 19, 2014
      • 112
      I use APS Tower Paint Co http://www.apstowerpaint.com/. They mix single stage lacquer for classics in various application methods. They are the only folks that I have been able to find still able to provide lacquer. Ph 1-800.779.6520. Mike I think your source is 2 stage and applying just the basecoat won't fully cure the paint. Its not lacquer per se.
      • Michael J.
        • January 27, 2009
        • 7166
        Mine cures fine, totally dry and ready to wax and buff after about 30 minutes. It is also nice and thick so it fills chips well.
