Please decode this engine stamp number - NCRS Discussion Boards
  • Darryl D.
    • February 7, 2017
    • 386
    FI207FC
    My memory is not what it once was. I think this is an engine that was installed in a 1957 model vehicle and decodes as a 1957 passenger car with 4 barrel (auto trans???)
  • Jim D.
    • 2885
    Re: Please decode this engine stamp number
    Depending on the casting date, it is either a 1955 265, powerglide, A/C, pass. car or a 1957 283,4 bbl., powerglide, passenger car.
    • Darryl D.
      • February 7, 2017
      • 386
      How can you say that with a stamped date of 12/7? It is an original stamped pad with the broaching marks.
      • Gary C.
        Administrator
        • October 1, 1982
        • 17930
        Darryl,
        You need to post the Cast block number and date - that's what Jim Durham's referring to.
        Photos are always best.
        Gary
        NCRS Texas Chapter
        https://www.ncrstexas.org/
        • Jim D.
          • 2885
          Look at the casting date on the block. Yours was assembled Dec. 7th. If the casting date is prior to that date in 1954, it's a 265. If it's prior to that date in 1956, it's a 283.
          • Leif A.
            • August 31, 1997
            • 3651
            It could be either 12/07/1955 or 12/07/1957...need to see the casting number. It, also, could be a 1956 or 1958 block.
            Leif
            • Jim D.
              • 2885
              Nope. You have the years wrong. That would mean that it was installed in a 56 or 58 model year. The assembly suffix shows it was installed in a 55 or 57 model year car.
              • Leif A.
                • August 31, 1997
                • 3651
                Jim,
                You're correct...should have said 12/07/1954 or 12/07/1956. However, according to the Lime Book the "FC" suffix was used on model year '56 and '58, and as we have both asked, we need to see the casting date. Thanks for catching my error.
                Leif
                • Darryl D.
                  • February 7, 2017
                  • 386
                  I can't see the casting date because the draft tube is in the way but the casting number is 3731548 which is a 283 engine no big X on the side of the block so not a 1958. I thought the stamped decode date was:
                  F=Flint
                  I2=Dec
                  07=7th day
                  FC= 1957 passenger car 283 4 barrel auto trans
                  • Gary C.
                    Administrator
                    • October 1, 1982
                    • 17930
                    Daryl,
                    You can use a mirror and flash light to read the casting date with the draft tube installed. You could also loosen the draft tube bolt and move it around to for better number visibility.
                    What are the heads cast number that are on your engine?
                    Gary
                    NCRS Texas Chapter
                    • Darryl D.
                      • February 7, 2017
                      • 386
                      Originally posted by Gary Chesnut (5895)
                      Daryl,
                      Gary
                      I believe the heads are from the original engine in the 57 and put on this engine because their date codes line up with the V.I.N. build date of the car. The heads are 3731539 dated A 9 7 & A 16 7 marked with the power pack pyramid on the front of the heads.
                      • Gary C.
                        Administrator
                        • October 1, 1982
                        • 17930
                        Daryl,
                        Is the power pack head pyramid machined smooth or have a rough texture to it?
                        The date code is very important. It would benefit you to tell us what the date code is under the vent pipe.
                        Gary
                        NCRS Texas Chapter
                        • Darryl D.
                          • February 7, 2017
                          • 386
                          OK, I got the draft tube moved far enough to see
                          the casting date but my 66 year old eyes could not read it. I cleaned it and
                          then took some plumber's putty on it to take an impression of it. So I will see
                          if I can figure out how to post a picture of this impression. It looks to me
                          like it is
                          L 8 6 and if they don't use "I" for Sept. due to confusion wit
                          1, then the date code is Nov. 8th 1956 which would be one month prior to the
                          stamped date of I207=Dec. 7th
                          • Darryl D.
                            • February 7, 2017
                            • 386
                            Sorry about the picture being upside down I thought I had flipped it.
                            The head pyramids are a rough texture.
                            • Patrick B.
                              • August 31, 1985
                              • 2011
                              It looks like L 6 6 which would be DEC 6, 1956 because "I" was used for Sept. The F1207FC matches perfectly with the Dec 6 casting date for a 1957 model year engine.
