65 washer question - NCRS Discussion Boards
65 washer question
  • John C.
    • December 30, 2010
    • 204
    65 washer question
    Hey guys, quick question. I have an unrestored 65 vert and have spent the last couple years trying to get the few items that were incorrect replaced with correct parts with correct dates, ie, alternator, carb, water pump, etc. Here's my question, the original washer bag is still in place, but I can see a small split in one of the seams and figure it most likely isn't water tight. I also haven't checked the washer pump which I feel certain would need rebuilding.
    So, in an attempt to keep the car as original as possible, would you suggest leaving the original washer bag even though it isn't water tight, or, replace it with a correct new replacement ? Also, as I understand it, judges will accept original parts on a car and not deduct points for parts that are original to the car, but, in this case, it would be impossible to check the washer pump since the "original" washer bag won't hold fluid ??????? How is this handled in the judging world ?
    JC
  • Leif A.
    • August 31, 1997
    • 3645
    Re: 65 washer question
    JC
    If you somehow can't "fuse" the seam on the original bag, I would certainly buy a quality reproduction and take the minor point(s) hit. If the bag doesn't hold water you will lose more points during operations check for non-functioning washers...just MHO.
    Leif
    • John C.
      • December 30, 2010
      • 204
      Thanks Leif ! Just hate to discard the original bag even though it isn't water tight. The mere fact it has been hanging there for 50 years is pretty cool. BTW, any favorites on a supplier for the pump rebuild kit ?
      JC
        • 43250
        JC
        John------
        You might be able to repair the washer fluid bag with some modern adhesive material. However, you'll be fighting a losing battle. The kind of material these bags were made of usually hardens and becomes brittle over time. So, new leaks will be right around the corner and, at some point, the bag might even "crumble". So, I'd say that that if you don't care about a working washer, leave it as-is. If you want a working washer, get a reproduction bag. Some things just wear out and cannot be restored.
        • John C.
          • December 30, 2010
          • 204
          With the advice given by the friendly NCRS guru's, I think what I'll do is buy a new bag, get the pump working, ( I assume it doesn't work ) so I'll know that it's in working order and then reinstall the original bag just because it's the original bag even though it leaks. If someone down the road wants it working again, all they'll have to do is reinstall the new bag.
          Thx Leif and Joe !
          JC
            • May 31, 1974
            • 8400
            i'd insert a zip-lock type bag inside the original. i've had a bunch of c-2's with washer fluid bags(as opposed the the plastic reservoir that the non-c-60 and non 396's were born with). all the bags were 50+ years old and still hold water. they are still pretty pliable too. so just get a plastic bag, insert it in your original bag, fill the inserted bag with washer fluid and forget it. unless its to be judged, then the judges may discover your inserted bag when they check for the filter being copper vs plastic generic filter. mike
            • John C.
              • December 30, 2010
              • 204
              Good idea ! BTW, of the 65's, which ones had a bag vs a bottle ? Maybe mine isn't original. My car is a L-79 (300/327)
              JC
              • Leif A.
                • August 31, 1997
                • 3645
                JC
                Does it, also, have factory AC?
                Leif
                • Tom D.
                  • September 30, 1981
                  • 2137
                  Bags went with the big block '65s (396) and those with C60 Air Cond., right?
                  https://MichiganNCRS.org
                  Michigan Chapter
                  Tom Dingman
                    • May 31, 1974
                    • 8400
                    JC
                    all the 65 396 equipped vets and any sbc 65's with AC would have had the bag vs a plastic jug/container. mike
                    • John C.
                      • December 30, 2010
                      • 204
                      Yes, it does have factory air. Thx Mike !
                      JC
