69 976 lemans Blue Paint spec - NCRS Discussion Boards
  • Mark B.
    • March 8, 2017
    • 119
    Good morning gents,
    I wanted to see if anyone has the proper paint spec for the 976 lemans Blue for my 69. If so please let me know paint mfg. I am going to be painting it soon and will be going base/clearcoat.
  • Donald H.
    • November 2, 2009
    • 2586
    Re: 69 976 lemans Blue Paint spec
    See the attached. Be careful with using the GM code 976 only. If you note on the attached, 976 was Nassau blue for 65/66, 976 was Marina blue for 67, and 976 was LeMans blue for 68 and 69.
    If you look at the paint codes, 65/66 976 Nassau blue was the same, however 976 Marina blue for 67 was different paint codes and even 976 LeMans blue for 68 was different than 976 LeMans blue for 69.
    I heard a story of a guy who's 66 was Trim Tag 976 and painted when he got it. He had it repainted some time later. The painter, a friend of mine, identified and used correct 976 for 66 Nassau blue. The owner didn't like it. Turns out his car was really 69 976 LeMans blue when he bought it and he didn't know the difference.
    Don
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
    • Mark B.
      • March 8, 2017
      • 119
      Don, thanks for the info, with all these slight variations in paint from year to year. Does anyone have the proper color metric make up by weight or oz that make up the proper 69 lemans Blue
      • Paul O.
        • August 31, 1990
        • 1716
        972 Can-Am White W041 8631 4714 1802 2517 3627 GMA70:10 -
        900 Tuxedo Black K090 9300 99 946 - 3069 - -
        976 LeMans Blue Metallic L1679 2083 5030 - - - - -
        980 Riverside Gold Metallic B797 2092 5029 - - 3946 GMA69:980 3950
        983 Fathom Green Metallic G1230 2079 5013 - - 3915 GMA69:57 3886
        984 Daytona Yellow Y476 2094 5026 2119 - 3916 - 3893
        974 Monza Red R502 2089 5027 2120R - 3944 GMA69:974 3894
        986 Cortez Silver Metallic S010 2059 5032 2108 - 3928 GMA69:14 3927
        988 Burgundy Metallic R850 50700 5063 - - 3529 GMA69:67 -
        990 Monoco Orange A192 2084 5021 2111R - 3920 GMA69:72 3959
        44 Olympic Gold Metallic Y694 2082 5010 - - 3918 - 3922
        • Mark B.
          • March 8, 2017
          • 119
          Are these accurate colors for the 976 or is one better then the other. I hear that Hue is different shades with base/clearcoat. Also i hear the metallics are different size from the original. is that correct
            • 11666
            Your best bet is to have your painter make some color spray outs with your preferred brand. Contact John Ballard, then send him the samples. He will give you guidance on what direction to tint the paint and get the right color. You might even contact John before you do the spray outs just to get guidance on clear coat types and brands.
            This is far easier in the long run than guessing over the internet, or finding out your $10000 paint job is the incorrect shade.
            • Paul O.
              • August 31, 1990
              • 1716
              Mark
              As Patrick stated use John for your best results.
              • Dick W.
                • 10483
                The chart that Paul posted was valid for the era of manufacture but all those codes are obsolete today. The paint jobbers will tell you that they have direct offset colors but if you believe that, I have some ocean front property in AZ to sell you. Spray out panels will be your best bet. Unless someone has come up with a newer metallic flake, you will have problems getting a 100% match.
                Dick Whittington
                • Mark B.
                  • March 8, 2017
                  • 119
                  New to the forum, how do you get info on John ballard to email or talk to?
                    • 11666
                    Region IV:
                    NCRS | Contact the National Corvette Restorers Society (NCRS) for assistance with membership, events, technical support, and more. Find contact details for regional representatives, NCRS leadership, and specialized departments to help you with all your Corvette restoration needs.
                    • Joseph S.
                      National Judging Chairman
                      • March 1, 1985
                      • 886
                      Mark, You will not get a 100% match just by taking the paint manufacturers reference code and mixing modern BC/CC. Your painter will need to tint and reformulate the color to match an original sample. Sometimes due to the metallic and side tone movement in the color it's best to start with a completely different color than what they have as a comp color. Be prepared for an event if you want to get it 100%. We have gone through up to 56 sprayout samples to get colors 100%.
                      • Ralph S.
                        • February 1, 1985
                        • 935
                        Still liquid after 47 years
                        • Dick W.
                          • 10483
                          Ballard is suffering the after effects of the flu. He is way less than 100%. I talked to him yesterday afternoon
                          Dick Whittington
                          • Frank T.
                            Infrequent User
                            • March 20, 2013
                            • 26
                            I have a good formula ,it's DuPont ,John helped us tweek it ,it judged very well 0 deduction on paint I will gladly help with formula call me Monday
                            at work 321 633 3227 (harbor auto restoration )
                            • Mark B.
                              • March 8, 2017
                              • 119
                              Thanks I will
