Fitting 1971 Radiator support - NCRS Discussion Boards
  • Phil A.
    • April 30, 1982
    • 121
    1971 Radiator support appears to fit snug when putting it back in after restoration. How do you determine whether it needs shims either on the sides or bottom? Thanks in advance Phil.
  • Russ S.
    • April 30, 1982
    • 2163
    Re: Fitting 1971 Radiator support
    After it is in place if there is a gap between the inner fender and the support, put a shim in.
