327/350 HP cam in 283 - NCRS Discussion Boards
  • Bob B.
    • March 1, 2003
    • 831
    Hi all,
    I have a 283 245 HP engine that has a 327/350 HP cam in it. I haven't installed or started the engine. Someone told me that this would yield poor low-end torque and that I ought to put the stock cam back in it. I am not going to hot rod the car this engine goes in. So, should I take the 327/350HP cam out and put the stock one in?
    Bob
  • Joe R.
    • July 31, 1976
    • 4551
    Re: 327/350 HP cam in 283
    Bob,
    Yes, you should immediately take the 151 cam out and send it to me!
    Jokes aside!!!!! The 350 151 cam is a great cam and has great torque at low end.
    The earlier 365 and 375 cam along with the LT-1 (dog) has NO torque!
    JR
    • Jimmy G.
      • November 1, 1979
      • 977
      Agree keep it Best cam (overall) that Chevrolet ever made
        • 15706
        It will have less low end torque than the OE cam, but a little better than the Duntov cam in the 270.
        • Bob B.
          • March 1, 2003
          • 831
          Joe & Jimmy,
          Thanks for your answers that make sense. It didn't make sense that the same cam with X lift and X duration in a larger displacement 327 with larger valves would perform differently in a smaller displacement 283 with smaller valves. It seemed like six of one and a half dozen of the other to me.
          Bob
          Bob
          • Joe R.
            • March 1, 2002
            • 1356
            Originally posted by Bob Baird (39424)
            Joe & Jimmy,
            Bob
            Bob
            Actually, it does make sense. Larger displacement engines are more tolerant (smoother idle, more vacuum) of long duration, high overlap cams.
            That being said, the L79 327/350 is a great all-around street cam for the 327. It will idle a little worse in a 283 and have less low-end torque than it would have in a 327, but I'd still leave it in the 283 provided you have a manual trans. It will have a rather lumpy idle at around 750 rpm, but will still be an entirely reasonable performance street cam for a 283. Far better than the 30-30 cam or the LT-1 cam.
            • Bruce B.
              • May 31, 1996
              • 2930
              I had a 283 250 HP FI engine with the 151 cam, perfect, good vacuum (114 LSA), great performance and sounded great.
              I also have a 327 with the 151 cam with Hilborn injection which I converted to EFI, again perfect for the application.
              But I do miss the sound of solid lifters which I have in my 340 HP 62 Corvette.
