70-72 copper radiator code tag and overflow tube clip - NCRS Discussion Boards
  • Mike E.
    • February 28, 1975
    • 5153
    I know the MK9 and the A K hose clip come from my 71 LT1 and are correct. Any idea what the MC4 and the A O clip come from? Why would the clips have identification info on them? The A O is about 1/16 inch shorter that the A K, and has a slightly different taper at the bottom end. Any input and help appreciated--always trying to learn!
    • 43290
    Re: 70-72 copper radiator code tag and overflow tube clip
    Mike------
    I believe the MC4 coding denotes the GM #3030199 radiator used for 1973-76.
    • Mike E.
      • February 28, 1975
      • 5153
      Thanks, Joe. You are so often helpful.
      • Russ S.
        • April 30, 1982
        • 2163
        Joe, Do you know if the MC4 tag is for a 4spd or auto?
          • 43290
          Russ------
          I believe the GM #3030199 radiator had provisions for transmission oil cooler. However, it could be used for either 4 speed or THM.
          • Russ S.
            • April 30, 1982
            • 2163
            But a 4spd car didn't come from the factory with the cooler provisions. Correct??
            Russ------
              • 43290
              Russ------
              As far as I know, it did not. However, the radiator with transmission cooler, GM #3030199 was ultimately used for SERVICE of both 4 speed and THM-equipped 1973-E1976 Corvettes.
              • Russ S.
                • April 30, 1982
                • 2163
                That would sound right. Thanks
