GM 103397, 103374, an 103386 Cotter Pin Sizes - NCRS Discussion Boards
  • Bill L.
    • February 1, 2004
    • 1403
    Reassembling rear suspension and looking for the correct sized cotter pins.
    Thank you,
    Bill
  • David B.
    • March 1, 1980
    • 689
    Re: GM 103397, 103374, an 103386 Cotter Pin Sizes
    103397 1-1/4" 5/32 plain
    103374 1" 3/32 plain
    103386 1-1/4" 1/8 plain
      • 43222
      Dave and Bill------
      Yes, virtually all cotter pins originally used on Corvette were of "plain" finish. Of course, this finish rusts rapidly especially on the chassis where most cotter pins are used. Using stainless steel cotter pins (rather than far more common zinc plated type) best replicates the original finish without being susceptible to rust. Unfortunately, the "loop style" of most stainless steel cotter pins is usually different than the style used on most original GM cotter pins.
        • 11644
        Here you go:
        • Bill L.
          • February 1, 2004
          • 1403
          Will these be stainless or plain steel?
          I treat the plain still with RPM to prevent rust.
          Thank you! Bill
            • 11644
            I assume steel, but I'm sure you could call CC and ask.
              • 43222
              Bill and Patrick------
              It says in the product description that they are zinc plated steel. Very few of the cotter pins used in PRODUCTION were zinc plated. Most were "plain" (i.e. unfinished) and rust fairly quickly.
                • 15601
                Back when we (Peter Lindahl & I) provided the cotter pin kits to CC we included instructions for removing the zinc plating. We have been out of that business for several years, so I don't know what information is included in their kits.
                We provided them plated because plain cotters would begin to oxidize in storage, handling and packaging. Immersing the cotters in a mild acid, like lemon juice, overnight will remove the zinc plating if that is your desire.
                  • 43222
                  Terry-----
                  Actually, I do not recommend removing the zinc plating. I mention that most originals were not plated for the sake of accuracy but I wouldn't go so far as to use un-plated cotter pins. I'd use stainless steel or zinc plated. I hate rust.
                  • Gary B.
                    • July 31, 1979
                    • 926
                    In rust we trust.
                    Vinegar works good also getting zinc plating off. If your in a hurry, Muriatic acid for swimming pools works really well. CRC Sp350 (metal preservative) on them and they look good for a long time.
                    Gary
                    • Bill L.
                      • February 1, 2004
                      • 1403
                      Originally posted by Gary Bosselman (2575)
                      In rust we trust.
                      Gary
                      Hi Gary,
                      I will remove the plating and apply RPM to the cotter pins. Used the RPM on my differential 3 or 4 years ago and not a spec of rust. Same is true of cotter pins already installed elsewhere.
                      Kind Regards,
                      Bill
                        • 15601
                        In rust we trust.
                        Gary
                        Be very careful with Muriatic Acid. The vapors from it will oxidize (rust) everything in your garage. I have no swimming pool maintenance experience, so I don't know what concentration of this product is used in them. Where are our chemically dependent members?
                          • 43222
                          Terry------
                          Muriatic acid is a term often used in industry for hydrochloric acid. It's actually an obsolete term but it's still widely used. If I were going to use it for removing zinc plating from cotter pins, I would use an extremely dilute solution. Actually, I think using something like citric acid or acetic acid would be safer and better. Vinegar represents an easy source for acetic acid.
