What Shim is this from 59 - NCRS Discussion Boards
+ More Options
Posts
  • Geoff C.
    • May 31, 1979
    • 1613
    I CRShim?
  • Ian G.
    • September 3, 2007
    • 1124
    Re: What Shim is this from 59
    I have a 59 and have never seen that shim.
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11334
      Need more info.....
      Is it aluminum or steel?
      Thickness?
      Hole diameter? (3/8" ?)
      Hole center to center spacing? (looks apx 3 3/4")
      Appears to be more of a reinforcement than a shim.
      Rich
      • Bob J.
        • December 1, 1977
        • 716
        Reminds me of a 62 powerglide starter shim/spacer.
        • Loren L.
          • April 30, 1976
          • 4104
          Geoff, shouldn't you be at the warehouse doing inventory, rather than causing consternation on a Sunday?
          • Pat H.
            • December 1, 1996
            • 420
            There was nothing like that on my 59 when I disassembled it for a restoration. What area did it come from?
            • Geoff C.
              • May 31, 1979
              • 1613
              I thought these flat steel parts were from a couple of 59's I raped, molested & dismembered. Boned out to the very last dash board metal bracing. Totally filleted. There are 5 pieces; all identical; the Zinc plating added by me - as everything was re-plated in Zinc because it was cheap.
              Any how they may have arrived with a pick up bed load of 53-57 parts purchased after a 1970's Greenwich, CT swap meet from another part ***** on LI who shall not be named.
