deck lid fitup - NCRS Discussion Boards
deck lid fitup
  • Chuck B.
    Infrequent User
    • August 29, 2007
    • 7
    deck lid fitup
    Gentlemen,
    After a body off restoration of my 67 vert, I found that the deck lid is hard up against both sides when latched. I removed all body shims under that location, and no change. I can't see how the deck lid wedges or the hinge positioning could help this situation. No filler was added to the deck lid or body in this area. Any ideas?
  • Douglas L.
    • August 31, 2003
    • 299
    Re: deck lid fitup
    Hey Chuck,
    How is the fit on the doors? If the doors are not in yet, I would put them in first. If the doors are already in and fit OK, then I would suggest you loosen the body bolts to the point where you can lift the body from the underside to see if there is a position where the distance between the two upper sides spread apart. You said you already took out all the shims from the mount just ahead of the rear tires. I would try adding shims to either the rear mounts or the mount at the front of the door. Good luck with it.
    • Chuck B.
      Infrequent User
      • August 29, 2007
      • 7
      Re: deck lid fitup
      Thanks Doug,
      i will try it this weekend. The doors are in and fit pretty well.
