Wiper Switch 1972 - NCRS Discussion Boards
Wiper Switch 1972
  • Guy B.
    • February 3, 2017
    • 32
    Wiper Switch 1972
    Looking for a little guidance, I have a 1972 Corvette that has just completed a total restoration. When the wiper switch button is pressed/pushed I get nothing at all. If I pull down the wiper door over-ride under the steering wheel the wiper door opens perfect and then if I slide the wiper switch over I get hi and low speed wipers no problem. So the system is fully functional just don't know why nothing happens if I press the wiper button. It's a new restoration so I really don't want to start tearing everything apart. Anyone have any idea where I should start?
    Guy
  • Ed D.
    • December 1, 1990
    • 329
    Re: Wiper Switch 1972
    Check the wiper arm seat position switch on the passenger side. If the wipers dont seat on the switch nothing works. When you override the system does the door close when you shut it down?
    Ed
    Ed DiNapoli
    CNJ Chapter Past Chairman/Co Founder
    1972 Targa Blue Coupe, Original Owner,
    Duntov Award, Sam Foltz Award,
    Founders Award, NCRS Gallery VIII
    2011 Corvette Convertible
    NCRS Presidents Award 2014
      • 43259
      Guy
      Guy------
      Check for a bad ground.
      • Guy B.
        • February 3, 2017
        • 32
        Ed,
        I took a look and it looks like the wiper arm is resting on the switch. If I open the wiper door manually and shut the car off it stays open.
        • Guy B.
          • February 3, 2017
          • 32
          Joe, you mean bad ground on the wiper switch it self? These dam Corvette are one big bad ground lol.
          • Joseph S.
            National Judging Chairman
            • March 1, 1985
            • 895
            Guy, The first thing that the switch does is activate a vacuum relay which opens the wiper door. The relay is mounted behind the dash near the tach. It should have a blue wire and a power,. The blue wire is from your wiper switch. You need to also check that you have vacuum here and it is plumbed properly. I hope this helps, Joe
            • Guy B.
              • February 3, 2017
              • 32
              Thanks Joe, I need to clear up these issues (and a few others) hope to get the car the LI judging in June. Maybe I see you there.
                • 43259
                Guy------
                Yes, on the wiper switch.
                • Jeffrey S.
                  • May 31, 1988
                  • 1892
                  GUY,
                  You said when you "push" the wiper switch nothing happens. Did you slide the switch to the right with the door closed or just push it in. Pushing the switch in activates the washer. I may be wrong, and please correct me if I am, but if one of the 2 black ground wires at the washer pump are not making contact, nothing will happen. I'm not sure if the wipers will start in this case or not but check here.
                  Jeff
                  • Guy B.
                    • February 3, 2017
                    • 32
                    Jeff, I am going to re-check my statement but I was under the impression when the washer button is pushed the door should open, washer should function and wipers should be on.
                      • 43259
                      Guy-----
                      That's how it should work.
                      • Joseph S.
                        • March 1, 1985
                        • 895
                        Guy, You are correct. There is a ramp in the switch that slides the switch to ON position when you push it in for washer operation. Then you would have to manually shut the wipers off.
                        • Jeffrey S.
                          • May 31, 1988
                          • 1892
                          Thanks for making the correction. It's been a long time since I used this and I thought it was something to check.
                          Jeff
