Did any of the 327 heads have the holes for staggered bolt valve covers? - NCRS Discussion Boards
  • Darryl D.
    • February 7, 2017
    • 386
    I would like to run my 9 fin valve covers on 327 heads.
  • Bob W.
    • December 1, 1977
    • 802
    Re: Did any of the 327 heads have the holes for staggered bolt valve covers?
    Darryl NO all of the 327 heads ihave seen do not.
      • 43248
      Darryl------
      You're out-of-luck. No 327 heads were ever made with staggered valve cover bolt pattern. In fact, no late 283 heads were ever made this way, either. Of course, you can use early 283 heads on a 327 but I do not recommend it.
      • Mike M.
        • May 31, 1974
        • 8400
        i wanted to use a pair of staggered valve covers on a pair of 2.02" 327 heads. JB weld didn't work. i then brazed mounds where the staggered covers needed their attachment. then drilled and tapped the brazed material. did this in the early 90's when the maryland missile was fooling with the dipstick of lyle,washington . those heads still power the white 57 Corvette. mike
        • Darryl D.
          • February 7, 2017
          • 386
          Yeah, I think the solution is to use 327, 350 or aftermarket aluminum heads and drill and tap them to take the original covers.
            • 43248
            Darryl------
            You can't just drill and tap the heads for the staggered bolt pattern. As Mike mentions above, you have to add material in the area of the new holes. The heads have small bosses in the area of the holes to provide the material thickness necessary to support the 1/4-20 tappings.
