'67 Hood Stripe Points - NCRS Discussion Boards
  • Gary J.
    • April 1, 1980
    • 1246
    When judging '67 hood stripe, how many points could you loose if the strip is not put on straight? I know there are a lot of variables here, 40 points is what available on body paint. Straight would be the big and little stripe at end of the nose hitting at the body peaks lines.
  • Joseph S.
    National Judging Chairman
    • March 1, 1985
    • 930
    Re: '67 Hood Stripe Points
    How many original stripes have you seen that were perfect? If a deduction would occur, they would need to figure out what percentage of the paint was included in the stripe application. I would think no more than 10% of the car so 4 points total for the stripe. So consider that you have an installation issue (20%) of those 4 points, you have a 1 point deduction. That's how I would judge it, but what the heck do I know?
    • Leif A.
      • August 31, 1997
      • 3654
      Other_than_the_fact_that_you're_a_Level_400_Master _Judge_(Red_Hat)_and_have_received_multiple_Top_Fl ight_awards_on_your_own_"67...I_would_hazard_,_pro bably_quite_a_bit
      Leif
      • Gene M.
        • April 1, 1985
        • 4233
        I think Joe is giving a good example of the CDCIF points allocation and how he would divide it up. good explaination
        • Stephen L.
          • May 31, 1984
          • 3162
          Gary,
          The stripe dimensions are in the AIM L36 A17.
          E-mail me if you need some help deciphering.......
          • Richard M.
            Super Moderator
            • August 31, 1988
            • 11364
            Joe, Very good analysis as usual.
            Question.....Wouldn't there be a deduct if the stripe was perfectly straight, in particular, at the front nose area where it's pointed? It wasn't originally mechanically straight between both sides was it?
            I suppose it makes a difference where the "crookedness" is though.
            Rich
            • Joseph S.
              • March 1, 1985
              • 930
              Rich, Considering the fact that ideally the stripe should be straight, I don't believe that a deduction is proper if your stripe was straight. I will tell you this, I have taped over 50 Hood stripes and have never been satisfied that any of them were either straight or symmetrical. It is close to impossible to achieve. That being said, I'm sure the guys at the factory had similar experiences trying to do it as quickly as they had to.
              • Richard M.
                Super Moderator
                • August 31, 1988
                • 11364
                Joe, Always great info. Thanks for the explanation.
                Rich
                PS All those years in the 80's and 90's I worked in Billerica right around the corner from your shop. I wish we knew each other then.
