Brake light switch 1957 - NCRS Discussion Boards
  • Dino L.
    • February 1, 1996
    • 694
    I have a couple questions as I repair my switch.... my lights are on but the brake light switch does no work. A quick look under the dash reveals the rear Mylar cap and leads popped off and their is an exposed spring... question one is this switch normally opened or closed? Second what are the internal parts besides the black button and spring and third can I use the guts from a door jamb switch from a C1 to repair or salvage parts?
    Dino Lanno
  • Bruce B.
    • May 31, 1996
    • 2930
    Re: Brake light switch 1957
    Normally open, closes to turn on the brake lights.
    The door jam switch is totally different then the brake light switch so the parts are not interchangeable.
      • 43250
      Dino------
      I think I'd be looking for an NOS GM #1998030. However, it will probably be expensive.
      One important thing: you want a brake light switch that works RELIABLY. You don't want someone running into the back end of your car.
