Correct alternator for 1978 L48 base corvette - NCRS Discussion Boards
  • Mark B.
    Infrequent User
    • April 18, 2016
    • 16
    I need to either have my original alternator rebuilt or replaces. What is preferred from a judging standpoint. If I need to replace what is the proper replacement alternator for max points? Thanks !!!!
    • 6954
    Re: Correct alternator for 1978 L48 base corvette
    Mark if the alternator is the original, You'll want to have it rebuilt, look for a local rebuilder in your area. sometimes you can find a independent rebuilder. try googling it.
    • Mark B.
      Infrequent User
      • April 18, 2016
      • 16
      Thanks Ed. That's kind of what I anticipated as I do have the original on the car. Also, I need to repair/replace the two prong connector (has the brown and red lead). Any thoughts on where I can get a replacement pigtail. The only one I have seen on line to date has a white and red wire. Thanks again for your help and have a great day!
        • 6954
        Mark the auto parts store maybe able to find this part. or maybe even the rebuilder.
        • Mark B.
          Infrequent User
          • April 18, 2016
          • 16
          Agreed,,,,,Zip Products had red and white vs red and brown. My search begins!
            • 6954
            Mark, sometimes you can remove the wires from the plastic connector housing and replace the terminals. I can look later and see if I have something that will work. do you need both connectors?
            • Mark B.
              Infrequent User
              • April 18, 2016
              • 16
              thanks Ed. I have a couple C3 buddies looking to see what they have as well. If you find something that can help let me know in case I strike out on my end....much appreciated!
              • Leif A.
                • August 31, 1997
                • 3648
                Be SURE that your rebuilder rebuilds YOUR alternator and not give you one that's already been rebuilt. Can he date code the diodes, as well?
                Leif
                  • 6954
                  Leif, Diodes are not seen on the these style alternators.
                  • Leif A.
                    • August 31, 1997
                    • 3648
                    Later C3...you're absolutely correct!!
                    Leif
                    • Mark B.
                      Infrequent User
                      • April 18, 2016
                      • 16
                      thanks Leif and Ed. I am definitely selecting a rebuilder who will rebuild and return my alternator. I have a line on one such outfit as I type. And correct, the diodes are not able to be seen.....
                        • 43263
                        Mark------
                        You could rebuild it yourself. These alternators are not difficult to rebuild. Usually, all that is needed are bearings and brushes. However, you do need to test all other components as described in the factory service manual. It's very easy to do the testing. Replace any parts that don't check out.
                        • Mark B.
                          Infrequent User
                          • April 18, 2016
                          • 16
                          Mark------
                          thanks Joe, that may be my next step if I cant find a reliable restorer
                            • 43263
                            mark------
                            The other advantage of rebuilding it yourself is that you keep the alternator in your possession. For those like me that are "anal" about losing original parts, that's a BIG advantage. However, if you come to the conclusion that you don't feel qualified to do it yourself, then you have no choice but to trust in someone else.
