66 427/425 choke assembly? wrong parts? - NCRS Discussion Boards
  • William B.
    • April 30, 1975
    • 942
    Can some one post a picture of the correct set up for a 66 427/425hp choke assy hook up? I have the correct 3247 carb and what I thought the correct choke set up, but can not make it work. Pictures always help
  • John B.
    • January 30, 2017
    • 3
    Re: 66 427/425 choke assembly? wrong parts?
    tell me where to take a picture and i will try to help
    • William B.
      • April 30, 1975
      • 942
      Thank you for fast reply. Please remove the air cleaner, and take a picture, from the right side of the carb/manifold showing the hook up from the manifold to the side of the carb.
        • 43259
        William------
        It's really a quite simple system. It consists of a choke thermostat (coil type), thermostat cover, choke rod which connects the coil to the choke lever on the carburetor, and a special retaining clip on the carburetor end of the rod.
        The choke coils are beautifully pictured in the Dr. Rebuild catalog with a wonderful explanation of the two types (make sure you have the right one for a Holley carb). Dr. Rebuild has available the thermostats, the correct interconnecting rods for every application, and the special clip.
        • Donald A.
          • March 1, 1987
          • 243
          • William B.
            • April 30, 1975
            • 942
            Don, GREAT pictures!! Exactly what I needed, Thank You!
