base 2" exhaust system 67 300 hp - NCRS Discussion Boards
  • James H.
    • October 29, 2015
    • 73
    Need to replace base 2" exhaust midas system. Who sells the most correct pipe muffler system ?
  • Harry S.
    • July 31, 2002
    • 5330
    Re: base 2" exhaust system
    I like Gardner -----> http://www.gardnerexhaust.com/
    You get to weld the mufflers on with a Gardner setup. Some parts houses sell sets with the mufflers already welded on the rear pipe. What year car?
    • James H.
      • October 29, 2015
      • 73
      base 67 300 hp
      • Harry S.
        • July 31, 2002
        • 5330
        Powerglide or automatic? Here is why I ask, per John Hinckley...
        The heat shields shown in that Assembly Manual sheet are used for both 300hp and 350hp engines with manual transmissions; both applications use the same 2-1/2" front exhaust pipes (and intermediate pipe and muffler assemblies), although they're swaged down to 2" at the exhaust manifold outlets. The only application that used 2" pipes was the 300hp Powerglide, and the part numbers for those matching 2" shields are shown on the M35 Contents sheet.
