1963 Radiator 340HP - NCRS Discussion Boards
1963 Radiator 340HP
  • Rob A.
    • February 8, 2011
    • 135
    1963 Radiator 340HP
    Here is a picture of the radiator in my 1963 survivor coupe. Can someone tell me if this it original? It does not have the Harrison decal. DeWitts is having a sale this month and if this radiator is not original I'm considering replacing it.
    Thanks for the help!
  • Leif A.
    • August 31, 1997
    • 3644
    Re: 1963 Radiator 340HP
    No picture Rob. Even if it is original I would consider the new DeWitts...don't know how comfortable I would be riding around with a 54 year old radiator.
    Leif
    • Rob A.
      • February 8, 2011
      • 135
      Here is the picture, sorry
      • Bob J.
        • December 1, 1977
        • 716
        No, it is not original.
        Bob Jorjorian
        • Rick A.
          • July 31, 2002
          • 2147
          agree with Junkie
          Rick Aleshire
          2016 Ebony C7R Z06 "ROSA"
          • Richard M.
            Super Moderator
            • August 31, 1988
            • 11334
            I concur with Leif and Rick and Bob on all counts.
            I was fortunate in '07 when we got our '63 coupe it had it's original 63A unit(Jan), late Feb built car, but I was always worried it would fail at a inopportune time. Surprisingly it's still holding liquids with the new owner since '10 in a far away place.
            • Rob A.
              • February 8, 2011
              • 135
              Thanks for the replies. Can you educate me on what visually makes it incorrect/non-original?
              • Richard M.
                Super Moderator
                • August 31, 1988
                • 11334
                Rob, The telltale to me was the neck on the drivers side.
                Here are some photos of the 63A from our coupe, which I think was the original. The only thing that was unusual was the center welded raised section for the upper rubber mount. It was discussed then that it was not the typical configuration. I just looked at my old 5th Edition JG and it should be 2" not 1 1/4" as I showed.
                Maybe Bob and others can follow up with their thoughts.
                edit....It appears it may be a brass replacement as it has a side tank. Originals were stacked plate aluminum.
                Rich
                • Richard H.
                  • March 1, 1995
                  • 45
                  Here is a similar shot of my Oct. '62 built car with it's original radiator.
                    • 43247
                    Rob-----
                    This is a copper/brass replacement radiator, for sure. After the GM discontinuation of the GM #3155316 radiator and before the DeWitts reproduction became available, this type of radiator was about the only choice if one needed a radiator for most 63-72 Corvette small blocks. Even when the GM radiator was still available many folks chose to go this route for cost reasons (about $200 versus about $700). I NEVER recommended these radiators, though. Among other reasons, they do not cool as well as the aluminum originals.
                      • 6950
                      Rich, Good post, Not a lot of the 63 judges know about the bigger mounting tab on 63 only Radiators.
                      • Timothy B.
                        • April 30, 1983
                        • 5196
                        Richard Heys,
                        I hope you don't mind me telling you this but your alternator belt is on the wrong pulley grooves. To be correct it goes on the forward pulleys on the crankshaft and water pump.
                        • Richard M.
                          Super Moderator
                          • August 31, 1988
                          • 11334
                          Edward, I never really got a definitive answer regarding my radiator. It just seemed odd that the question arose then regarding the width of that standoff tab. It's hard to imagine that it would have been replaced with a January 1963 built service replacement, but maybe warranty when delivered in late February. Who knows.
                          Rich
                          • Rob A.
                            • February 8, 2011
                            • 135
                            Thanks all for the input. I will order the DeWitts replacement. Now I will just have to figure out how to give it the right patina so it doesn't stand out.
                            • Stuart F.
                              • August 31, 1996
                              • 4676
                              Had to replace my original 63 radiator in 1975 as when I changed the "uncle burn" from I believe Prestone to Zerex it started to leak like a sive from many places. Probably had some sort of chemical reaction. I've never used Zerex ever again for any of my cars. It may not have been the cause, but I had to blame something. So, my radiator is dated as a 1975 replacement, but this one has lasted well now for only 41+ years and still cools. I still keep a close eye on it for first sign of failure or inefficiency. Understand the crud starts building up inside from the bottom up over time.
                              Stu Fox
