1954 turn signal canceling - NCRS Discussion Boards
  • Guy M.
    • November 1, 1993
    • 500
    When driving and using the signals, it doesn't come back to exactly center which causes the right tail light not to work when the brakes are applied. I have to physically center the lever by hand a tad to get it to center. Any thoughts on a fix that gets the cam back to center? These things don't work all that well even with new stuff. I even have a little white lithium grease on the friction points. Thanks again.
  • Lynn L.
    1953-55 Team Leader
    • February 1, 2000
    • 162
    Re: 1954 turn signal canceling
    The bell housing is often oblong, be sure the turn signal clicks into detent when using turn signal. If this is correct, applying more tension to cancelling, return springs should correct problem. Again obvious click when setting turn signal followed by obvious click when cancelling when turning wheel to return lever. The signal switch has 2 heavy wires in the hub for return springs. These can be opened by hand to increase tension.
    • Chris S.
      • January 1, 2000
      • 1067
      the aftermarket turn signals for our cars is poor
      you can try Lynns fixes above
      you can also try to improve the metal cancel bar.
      1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
      Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
      1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
      1957 Corvette - FI 3 sp - Black and Silver
      • Guy M.
        • November 1, 1993
        • 500
        Thanks Lynn and Chris. Ill try these remedies. The signals work good except for getting back to center.
