C1 ignition switch - NCRS Discussion Boards
C1 ignition switch
  • David H.
    • November 11, 2009
    • 777
    C1 ignition switch
    My ignition switch appears to be incorrect because as you can see in the picture only one of the key notches lines up correctly.
    Am I correct?
    What is the correct part number for this part?
    Mine has 577 on it.
  • Wayne L.
    • September 30, 1981
    • 233
    Re: C1 ignition switch
    The 1116577 switch is correct for 60-62 Corvettes.
    • David H.
      • November 11, 2009
      • 777
      Interesting...
      so why don't the keys line up with the slots?
      • David H.
        • November 11, 2009
        • 777
        Oh, wait, is it the single key on the switch that lines up in the slot?
        Why are there two slots?
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11325
          David, I'm heading to my shop later where I'm restoring a '61. I can get some pics of the way the switch mounts with the escutcheon and threaded bezel. I need to do this anyways.
          But this may be your answer. Going from memory so I hope I have it right. On the switch that one tab with the small steps on each side locates it in the panel slot at 9:00. The extra slot in the panel(12:00) is to align the round chrome spacer on the front side to hold the black plastic escutcheon(LOCK OFF ON START) in place. Then the threaded bezel is installed on the threaded switch nose which holds everything in place.
          The round spacer below. Notice the tab at 12:00 on the backside on the inner circumference which sits at 12:00 in the panel. This part is used on all 1958 to 1962 switches.
          Notice the escutcheon has a mating slot that the round spacer tab fits over at 12:00 This part is used on all 1958 to 1962 switches.
          Threaded bezel. (1960-1962)
          Before the round spacer is installed, set the switch in place from behind and place the escutcheon over it then the round spacer with its inner/backside tab at 12:00 into the panel slot. Then thread on the bezel and tighten securely while holding the switch firmly in place from behind.
          • Wayne L.
            • 233
            David-
            Rich has a good memory....he nailed this one!
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11325
              Wayne, Nice online photos and a little luck.
              So here is a picture sequence of the installation, along with some details of the differences of original to reproduction parts. I can't find my stash of original escutcheons but there is a noticeable difference in those as well. I''ll let the pictures do the talking.
              • David H.
                • November 11, 2009
                • 777
                Thank you Richard. Great instructions.
                I'll try this approach after the Patriot beat the Steelers!
                • Richard M.
                  Super Moderator
                  • August 31, 1988
                  • 11325
                  Since the game is over and your prediction was withstanding, you now have your switch installed, correct?
                  • David H.
                    • November 11, 2009
                    • 777
                    Well, not just yet but tomorrow for sure.
                    Thanks again.
                    • David H.
                      • November 11, 2009
                      • 777
                      Went together perfectly!
                      Thanks for the help!
                      GO PATS!
