wheel cylinders - NCRS Discussion Boards
wheel cylinders
  • Howard H.
    • January 10, 2007
    • 139
    wheel cylinders
    I picked up a box of brake wheel cylinders at a swap meet a while back supposedly from a closed corvette restoration shop. I think at least part of them are early corvette. any help identifying them would be appreciated. Casting numbers are;
    5463821 5463822 5463820 5464079 5450649
  • Mike M.
    • May 31, 1974
    • 8400
    Re: wheel cylinders
    none of the listed #'s are 56-7 rear wheel cylinders. the 821 and 822 are front 56 all but SR-1's. they were also used on all 57's including the 684 HD sups cars. mike
    • John S.
      • July 29, 2009
      • 640
      Re: wheel cylinders
      821,822 front cylinders for 53 thru at least 59, 820 rear 53-55(need brass block and drilled bolt to connect to brake line). although there is just one number for the 53-55 rear cylinders(820) there is a left and right cylinder. I assumed 649 was the rear cylinder for C1s after 55. if it is not used on 56 and 57, it is used on 58 and later.
      • John S.
        • July 29, 2009
        • 640
        Re: wheel cylinders
        if 649 was not used on the rear of 56-57, what number was?
        • Howard H.
          • January 10, 2007
          • 139
          Re: wheel cylinders
          Thanks Mike and John; I threw the originals on my 58 away many years ago. Now I have originals to put back on it.
          • Pat H.
            • December 1, 1996
            • 420
            Re: wheel cylinders
            the 649 cylinders are the rears for 58-62 and maybe on 63-64's. These wheel cylinders seems to be around at swap meets in varying degrees of usability. From what I've read over the years the fronts 527-528's were used in 58 - 60 and I'm not sure when their usage discontinued. I did see a pair of the 8 series restored, but they did not appear to look like anything I've ever seen. Could they be for big brake cars?
            • John S.
              • July 29, 2009
              • 640
              Re: wheel cylinders
              I thought 60's are different than 58-59. I do see in the 58-60 restoration guide that the only front they show is a 528 with a date code of 1239, which may be for a 60. when you buy a front rebuild kit it is for a 53-59 and 60-62HD. 60-62 are 1 3/16". *** past post do show that 527 and 528 are the 1 3/16" 60-62 cylinders.***
