Starter question 54 Vette - NCRS Discussion Boards
  • Donald M.
    • March 27, 2015
    • 98
    Will a 12 volt starter work with an 8 volt battery? Wouldn't it just draw more amps to get the power it needs?
    I'm thinking about switching to a '62 powerglide which would mean I would need to use a 12 volt starter.
    Don
  • Jim L.
    • September 30, 1979
    • 1817
    Re: Starter question 54 Vette
    Have you ever heard a starter struggle and groan to turn over an engine when the battery Voltage was low? I believe that's what you'll notice when your 12 Volt starter sees only 8 Volts.
    • Donald M.
      • March 27, 2015
      • 98
      Jim,
      Now I feel stupid. I should have thought of that. You are absolutely right.
      Don
      • Mike M.
        • May 31, 1974
        • 8408
        you'll find the 6 volt starter will live a long life when fed by an 8 volt battery. back in the day, we'd run 6 volt starters on the olds and caddy powered hot rods that were converted to 12 volt systems and those starters outlived the engines. mike
        • Donald M.
          • March 27, 2015
          • 98
          I found a generator built with alternator guts that mounts in the stock position. The shop found this alternator put out enough voltage to charge an 8 volt battery, so I now have an 8 volt battery in my '54 Corvette. The additional voltage shouldn't hurt anything, and it should give the starter a bit more oomph for its cranking duties. This should be a good modification, and will not hurt the character of my car. I had heard of running 6v starters on 12v, and I'm hoping the change does not hurt other electrical components.
          Thanks for your comment,
          Don
          • Dan D.
            • November 5, 2008
            • 1323
            I did the same thing Mike. I used to have a 1952 Ford convertible with an Oldsmobile engine. My buddy had a 49 Mercury convertible with an Olds engine. Another friend had a Mercury with a Cadillac engine. They would never crank on 6 volts. We did the engine swaps by ourselves - with very few tools and no torches or welders. We converted them to 12 volts too. Never had any problems with the 6 volt starters. But boy - would they spin over. We had to configure the car for negative ground (the old Fords were positive ground). Those were the days!
            -Dan-
            • Dan D.
              • November 5, 2008
              • 1323
              8 Volts will stress the light bulbs Don. You may find they do not last very long. That's like a 25% over rated voltage.
              -Dan-
              • Donald M.
                • March 27, 2015
                • 98
                Yeah, I know. I'm hoping the bulbs have some tolerance. If not, I'll just replace them. I'll report back when I find out what happens.
                Don
                -Dan-
