1970 LT-1 Thermostat Housing - NCRS Discussion Boards
  • George C.
    • April 11, 2010
    • 44
    Did the 1970 LT-1 have bolts in both sides of the t-stat aluminum housing or was a stud with nut used on one side?
    • 43246
    Re: 1970 LT-1 Thermostat Housing
    George------
    A stud with a nut was not used on ANY Corvette application I know of for thermostat housing retention. What was used was a "double-ended" stud with a hex for the shorter position. The stud was once available from GM under GM #3776391 but it's discontinued. I expect that reproductions are readily available. The lower portion of this stud often suffers from corrosion damage and needs to be replaced.
      • 11659
      Approx page 155 of the new manual, as well.
      • Mike E.
        • February 28, 1975
        • 5140
        George,
        With as desirable car as you have, I'd encourage you to spend the money on the new manual. That purchase can ultimately save you many dollars in mistakes.
          • 15610
          Originally posted by Mike Ernst (211)
          George,
          There is a picture in the new 1970-1972 manual, for those who are visually inclined. A lot of the studs I see on restored Corvettes (all 1968-1972 small blocks had that stud) do not have the proper configuration. I don't know where they are sourced from, but there are a bunch of "close but no cigar" studs out there.
          • Rich P.
            • January 12, 2009
            • 1361
            Is this a Cuban or a knock off?
            • Jeff P.
              • 799
              68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
              2014 Arctic White Z51 Vert. (Wifes)
