Horn removal on C1 - NCRS Discussion Boards
Horn removal on C1
  • David H.
    • November 11, 2009
    • 777
    Horn removal on C1
    I expect I know the answer to this but thought maybe someone of you might have a magical trick to removing the horns from a '62 without removing the hood. I got the drivers side out by inhaling and and holding my breath while holding the hood upright.
    I am not being so lucky on the passengers side however.
    Any thoughts?
  • Mike E.
    • February 28, 1975
    • 5141
    Re: Horn removal on C1
    Nothing magical beyond double-jointed elbow and wrist. Be careful, because the nut plate rivets easily break, and then the bolt and nut plate spin. Then you have to hold on to both.
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11363
      I concur with Mike, but have a helper hold the hood at varying angles after you remove the bolts to the hood support. Protect the paint of the valence edge and the hood with something thin.
      • David H.
        • November 11, 2009
        • 777
        I was able to adjust the passengers side horn without taking it out.
