57 Radiator overflow tube and two clips - NCRS Discussion Boards
  • John N.
    • February 1, 1975
    • 451
    Need source for 57 radiator overflow tube and the two clips.
    Thanks!!!
  • Mike M.
    • May 31, 1974
    • 8399
    Re: 57 Radiator overflow tube and two clips
    john: one of my 56-57 vets was missing its radiator overflow tube and retaining clips. as i recall, the tubing is copper. i soldered a piece of copper tubing to the fill neck, then fabricated the clips. a local radiator shop should be able to fabricate what u need. regards, mike
    • John N.
      • February 1, 1975
      • 451
      Mike
      Thanks!!!
      John
      • Loren L.
        • April 30, 1976
        • 4104
        Does anyone have the blueprints from Harrison? I have the ones for the top tank radiators but that source is no longer active. I'll bet that those clips were used on other radiators......
        • Bob B.
          • March 1, 2003
          • 831
          John,
          A friend made this and sent it to me if you'd be interested in a repro one. Let me know and I'll check with him and see if he is still doing them. I don't know if these were put on by Harrison or by GM when installed, but they'd probably be on most GM cars, but you'd probably have to hunt junkyards for them.
          Bob
          • Dan P.
            • December 1, 1990
            • 683
            1957 Passenger car are the same DeWitts makes the tube.
            • David B.
              • March 1, 1980
              • 689
              Loren,
              I MIGHT have, will scrounge through prints.
