1970 axle shaft coating - NCRS Discussion Boards
  • Thomas B.
    • November 24, 2015
    • 26
    Hello. Can someone please confirm that the axel shafts were not coated with any paint, that they should be natural in color.
    Thank you.
    • 43221
    Re: 1970 axel shaft coating
    Thank you.
    Thomas------
    The half shafts were not originally coated with any paint or other coating. They were natural steel.
    • Thomas B.
      • November 24, 2015
      • 26
      Thank you for the confirmation.
        • 43221
        Thomas------
        By the way, half shafts for big blocks and some LT-1 had a shot-peened finish. This gave them a dull, slightly rough finish. Other small blocks received half shafts that were not so-treated and had a smooth, natural steel finish.
        • Joe R.
          • July 31, 1976
          • 4550
          Thomas,
          Your calling them axle shafts and Joe is calling them half shafts. Please clarify and would Terry please step in to see what and how these animals are judged?
          JR
            • 43221
            Originally posted by Joe Ray (1011)
            Thomas,
            JR
            JR-------
            For 1970 Corvettes, half shafts = axle shafts and axle shafts = half shafts.
            • Joe R.
              • July 31, 1976
              • 4550
              JR-------
              I sure that there are a lot of things on 1970 Corvettes that are different from C-2 Corvettes but half shafts ain't one of them.
              Please post some pictures as I am old and slow! If you need I'll post some pictures of axles vs. half shafts.
              JR
              • Thomas B.
                • November 24, 2015
                • 26
                Please see the attach picture
                  • 43221
                  JR
                  JR-------
                  OK, for 1963-67 Corvettes half shafts = axle shafts and axle shafts = half shafts.
                  GM's nomenclature for this part for all 1963-82 Corvettes is: REAR AXLE SHAFT. In the Corvette vernacular the part is often referred to as: HALF SHAFT
                  The other part you might be thinking of is referred to by GM as: DIFFERENTIAL CARRIER U-JOINT YOKE. In the Corvette vernacular these are often referred to as STUB AXLES or YOKE AXLES. I have never heard them referred to as axle shafts.
                    • 15599
                    Those are what most of us commonly refer to as half shafts. As Joe L points out, GM has a different nomenclature.
                    Joe L is also absolutely correct regarding their finish depending on the powertrain configuration. IIRC the latest 1970-72 TIM&JG has a close-up photo of the surface of a shot peened shaft. I didn't handle those photos, but I believe the vehicle in that photo had/has 4 miles showing on it. The latest 1970-72 TIM&JG has the world's largest collection of photos of original 1970-72 Corvette pieces. I may be a little biased (well, maybe a lot biased) but it is the best bang-for-your buck for 1970-72 Corvette fans.
                    • Russ S.
                      • April 30, 1982
                      • 2162
                      "bang for your buck" Is that what you get when you stomp on your high HP BB and the front drive shaft breaks, drops, catches the concrete and "buck"(s) the rear of the car Up? You then have to spend big "bucks"s for your="bang" Sorry, couldn't help myself. Terry McManmon (3966);793006]Those are what most of us commonly refer to as half shafts. As Joe L points out, GM has a different nomenclature.
                      Joe L is also absolutely correct regarding their finish depending on the powertrain configuration. IIRC the latest 1970-72 TIM&JG has a close-up photo of the surface of a shot peened shaft. I didn't handle those photos, but I believe the vehicle in that photo had/has 4 miles showing on it. The latest 1970-72 TIM&JG has the world's largest collection of photos of original 1970-72 Corvette pieces. I may be a little biased (well, maybe a lot biased) but it is the best bang-for-your buck for 1970-72 Corvette fans.[/QUOTE]
                      • Kenneth B.
                        • August 31, 1984
                        • 2089
                        That should explain the difference. The one on the right is a half shaft & the one on the left is a rear axle shaft. HUM or is the one on the right the axle shaft & the one on the left is the half shaft. Still having trouble figuring out the difference between a roadster & a convertible.
                          • 15672
                          A roadster has no top or side windows, and maybe a car with a folding top and "side curtains", like early post war English sports cars and early Corvettes could be considered as such.. A convertible has a folding soft top or removable hard top and roll up side windows.
                            • 43221
                            Kenneth------
                            Neither. Both are referred to in PRODUCTION parlance as "drive shaft" (what we think of as a drive shaft, PRODUCTION refers to as a "propeller shaft"). However, these are really REAR DRIVE SHAFT ASSEMBLIES. This includes the REAR DRIVE SHAFT + U-JOINTS + OUTER U-JOINT FLANGE. These assemblies were used in PRODUCTION but never available in SERVICE. In SERVICE, one had to obtain each of the components separately.
                            • Thomas B.
                              • November 24, 2015
                              • 26
                              Thank you everyone for your input. No coating is the way they will be installed.
