How to Adjust Alignment of Headlight Bezel When Open? - NCRS Discussion Boards
  • Mark E.
    • April 1, 1993
    • 4607
    When open, the bottom of the RH headlight bezel sits about 1/4" above the front surround. When closed, the headlight door is almost perfectly flush and aligned with the front surround.
    Is this "normal"? If not, how is this adjusted?
    Thanks folks!
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
  • Graeme B.
    • October 23, 2007
    • 213
    Re: How to Adjust Alignment of Headlight Bezel When Open?
    Hi Mark, there is a bracket attached to the headlight frame with a adjustment screw. I think ? you can get to it from underneath.
    Cheers, Graeme.
      • 6956
      Mark there should be some adjustments on the under side there a threaded stop I think you maybe able to see them with headlight up?? there is a full up and down adjustment I believe.
