1957 Radiator Core Support - NCRS Discussion Boards
  • Joseph L.
    • July 26, 2012
    • 162
  • Rod K.
    • 443
    Re: 1957 Radiator Core Support
    The core support extension is, I believe, attached with 3/16" X ?? aluminum round head rivets and bonding adhesive. Can't confirm that since my car is at the spa right now.
    JG shows 121887 as 1/4" X 1 in one entry and X .6 for another, WB1C or L. Doesn't show the radiator application specifically.
    JG also shows 120229 as 5/16" X .625 WB1C, L, UR or plain. Again, it doesn't specifically list the horn/radiator mtg app. AIM Sect 11, sheet 2 shows remainder of core support mtg bolts as 120229.
    Hope this helps.
    • David B.
      • March 1, 1980
      • 689
      #121887 1/4 -20 x 3/4 hex zinc also used on cowl vent bracket. Look there to verify, providing yours are original.
      #120229 5/16 - 18 x 7/8 hex zinc also used on seat belt anchor outer. Look there also to verify
      WB1C = course or NC
      WB2C = fine thread SAE
