1970 Ignition & Spark Plug Shielding - NCRS Discussion Boards
  • John M.
    • April 30, 2004
    • 111
    I am in the process of doing a full nut and bolt NCRS restoration to a 1970 LT1. In the judging manual it states that around serial number 14,000 the ignition sheilding changed and I have figured out that my car had the later style one piece ignition shield because my two orange brackets only have one nut welded to the inside. My question is should I have all four spark plug shields or only the two rear shields??? The judging manual is not clear on this. There are four inner shields of which I have all four originals, but I do not have any of the chrome outer spark plug shields. My car is 13,238. Thanks John.
  • Gary B.
    • July 31, 1979
    • 926
    Re: 1970 Ignition & Spark Plug Sheilding
    I would expect to see all four spark plug shields. I think the shielding changes came about with the CTK engines, but need to search more on that.
    Gary Bosselman
    • John M.
      • April 30, 2004
      • 111
      Thanks Gary, My car has the CTK engine!
      • Deane M.
        • January 2, 2007
        • 143
        Cars after s/n 11000 (approximately) would have the two rear shields only.
        Hope that helps.
        • John M.
          • April 30, 2004
          • 111
          Re: 1970 Ignition & Spark Plug Shielding
          Thanks Deane, Thank you for the info. Does that mean that my car would still have the two forward inner spark plug heat shields, just no forward outer chrome shields?
          • Mike F.
            • April 25, 2011
            • 668
            That is correct.
            • John M.
              • April 30, 2004
              • 111
              Thanks Mike!!
              • Richard K.
                • April 1, 1988
                • 207
                Interesting stuff. Why did the General feel there wasn't a need for the two forward chrome shields?
                  • 15614
                  Because they began using a RFI (Radio Frequency Interference) shield inside the distributor. This RFI shield prevented most of the electronic "noise" from the points opening and closing from interfering with the radio.
                  • Deane M.
                    • January 2, 2007
                    • 143
                    That is what I would expect to see.
                    • John M.
                      • April 30, 2004
                      • 111
                      Thanks Terry, Very interesting information. I am surprised they felt the need for any sound noise shields on LT1's with TI ignition (No Points??)
                        • 15614
                        I am not convinced any of that stuff was needed, points or not. I have friends who use solid core spark plug wires and no shielding and the radio works as well as expected until a spark plug or wire goes bad. Back in the day most of that chrome was removed at the first spark plug change. That is why so few cars have their original shielding.
                        I am surprised Chevrolet didn't eliminate it all as a cost saving measure. They seemed to nickel and dime every other part and system.
