Sticky Steering wheels - NCRS Discussion Boards
  • Gary R.
    • April 1, 1989
    • 1806
    Does anyone have a good method to remove the sticky gummy surface from the black 69-75 steering wheels? I have a couple that were in the garage for years and they all are sticky. The original one in my 72 is like new, why are they breaking down?
    Gary
  • Gene T.
    • May 31, 1997
    • 78
    Re: Sticky Steering wheels
    Have you tried Dawn and water ? Just a thought
    • Michael J.
      • January 27, 2009
      • 7167
      I use Goo Gone for things like that, works great.
      • Keith W.
        • June 30, 1998
        • 375
        WD 40 always works well on those sticky old half peeled off window stickers
        • Gary R.
          • April 1, 1989
          • 1806
          Thanks guys, I haven't tried anything yet. I did have similar issues years ago with the interior panels getting gummy and cleaned them with simple green & hot water. I'll get back once I get around to it, maybe start with the dishwashing soap first.
          • Bob W.
            • December 1, 1977
            • 803
            Gary I hope you or someone else comes up with an answer to this. As it seems a of lot other members have the same problem as we do.
            Bob
            • Brian M.
              • February 1, 1997
              • 1842
              I've used smooth Go Jo P/N 1115 and follow up with a protector of choice.
              • Bill C.
                • July 15, 2007
                • 904
                Gary
                I have had the same issues on several cars
                best I have been able to trace it back to is
                1 humidity
                2 mildew
                3 lack of sun light.
                Every car I have had garaged for long periods has had the slimy steering wheel
                I now have two de humidifiers running in my garage
                i cleaned the wheels with dawn and warm water
                and since the humidity is down low no more issues
                Bill
                • Gary R.
                  • April 1, 1989
                  • 1806
                  Thanks Bill, you may have the answer. These wheels were in my basement hanging on the wall but it's an old basement not sealed so that could be.
                  • Phillip M.
                    • September 30, 2006
                    • 100
                    Originally posted by Bill Chamberlain (47576)
                    Gary
                    1 humidity
                    2 mildew
                    Bill
                    Bill, I'm pretty sure the "slime" is actually plasticizer leaching out of the resin the wheel is molded from. This, depending on the resin/plasticizer chemistry, will naturally occur over time and may be accelerated by excessive temperatures. Efficient removal of slime will depend on the particular plasticizer used, and may require a certain amount of trial and error to determine what works best.
                    Phil M.
                    • Randy C.
                      • March 1, 1985
                      • 154
                      This happens to a number of steering wheels, not just necessarily Corvettes, of that era. In addition to my '71 Corvette, I have a '68 4-4-2 convertible and both of those steering wheels are fine. But I also have a '69 4-4-2 convertible and that steering wheel is constantly sticky. I've used wax and grease remover to keep it clean but in about six months it's sticky again. I'm going to try the other methods described above to see if they give me more than 6 months before I have to clean again!
                      Randy C.
                      • Richard T.
                        • February 1, 1979
                        • 858
                        I bought a new 69 and had this issue from day one. Complained to dealer and was told "They're all like that" Rich
                        • Mark E.
                          • April 1, 1993
                          • 4607
                          I have an original steering wheel that emerged sticky after being stored for many years with a cover on it. I tried several methods to correct this, with no success.
                          Then, after about a year of being uncovered, it miraculously returned to normal. I don't really know why.
                          Mark Edmondson
                          Dallas, Texas
                          Texas Chapter
                          • Jerry W.
                            • January 27, 2009
                            • 588
                            I another life on Saturday nights..( if i was lucky ) i had the same problem..Time solved the problem.
