I am restoring a basket case 65. There are no holes for the nose emblem. I see on the header bar underside 2 holes. Anybody have a template to drill to?
65 Nose Emblem Location
Re: 65 Nose Emblem Location
Brian,
Go to willcoxcorvette.com and in the search bar put in the year and search "emblem" and there is a page with some info to help you (offsets and dimensions, etc...). I don't know of a template. The info may be in the AIM as well but I'm not home now to look it up. Good luck.
Mike- Top
Greetings:
Ok, found it this time at Wilcox could not find it before. I will now look for the two holes shown at the front of the header bar. Did not look there before only through the 2 openings and did not see anything. Will look tonight and let you know.
Cheers,
Brian- Top
There's another page there that didn't come up right away, don't know if you found that as well. It didn't show till I clicked on it. It shows 1.75 inches from the top of checkered flag pole to trailing edge of nose piece and 2.5 inches from left most red flag fold (passenger side of emblem) to that same edge. Those measurements are on top of the nose. With a square and a tape measure and some masking tape you can position it from up top as well.- Top
