Tires for judging a '69? - NCRS Discussion Boards
  • Paul S.
    • October 29, 2015
    • 203
    Hi all,
    Are there any reproduction tires available for a '69 that will not receive a judging deduction?
    I am looking at a set of reproduction Goodyear Wide Tread bias plys, and I am being told that the only way to tell they are reproductions is by the serial number. Is this true? If so, I assume they would still receive a deduction. Is anything better available without going NOS? (Even if I could find NOS tires, I would be concerned about driving on such old rubber.)
    Paul
  • Harry S.
    • July 31, 2002
    • 5330
    Re: Tires for judging a '69?
    Paul, beyond the serial number there is also the DOT logo on the tire. Mandated by the DOT. It's a small standard deduction for reproduction tires.
    I'm sure the price of NOS tires far exceeds most budgets and certainly is not worth the standard deduction for reproduction tires. Besides that you would never drive on NOS tires anyway, they are unsafe.
    Essentially, take the point hit and worry about other larger point deduction areas.
    • Dave S.
      • August 31, 1992
      • 2926
      1969 Original tires would have the DOT marking. 1968 and earlier do not.
      Paul - Your advice is correct. The Goodyear RWL (not sure about the white stripe) reproduction tires are pretty much "spot on" and the only detectable difference is the debossed numbers/letters on the sidewall. All new tires (including reproduction tires) have a long code of 11 or 12 letters and numbers, the last 3 which represent the week and year. Original DOT tires from 1969 and 1979 have a shorter code of 8 or 9 numbers/letters which contain manufactures information but the last 3 are not the date as in this the later tires.
      • Mike F.
        • April 25, 2011
        • 668
        I also have the Goodyear Wide Tread repros from Kelsey Tires ($$$), the standard deduction is 2 pts.. How much $$$ is 2 pts. worth to you?
        FYI - I believe the repro Goodyear's judge better than the repro Firestone's due to an incorrect tire tread.
        • Dave S.
          • August 31, 1992
          • 2926
          I also have the Goodyear Wide Tread repros from Kelsey Tires ($$$), the standard deduction is 2 pts.. How much $$ is 2 pts. worth to you?
          Mike,
          It should have been 3 points. That is the standard deduction for that tire assuming the judges see that the debossed numbers are not like the originals. If you didn't have them the deduct would be greater than that.
          • Mike F.
            • April 25, 2011
            • 668
            Mike,
            Dave,
            Two Regional's, 2 pts. at each.
            Color me lucky?
            • Harry S.
              • July 31, 2002
              • 5330
              Dave,
              Color me lucky?
              It's only 2 points if you have a original spare. If not it's an error as it should be 3 points.
              • Mike F.
                • April 25, 2011
                • 668
                I have the original spare.
