Harley Earl's 68 Corvette? - NCRS Discussion Boards
  • Mike F.
    • April 25, 2011
    • 668
    Found this, http://www.vintagevettesllc.com/listing/1968-corvette-coupe-harley-j-earl/
  • Rich G.
    • August 31, 2002
    • 1403
    Re: Harley Earl's 68 Corvette?
    Did 68's have the blue GM label on the door? Mine doesn't
    Rich
      • 11678
      It's been known for quite a while. I believe it's gone through at least one auction (Kissimmee 2016) and a few dealers.
      • Mike F.
        • April 25, 2011
        • 668
        Rich
        In addition to that, door mirror location and painted underhood panel (infront of wipers) in relation to a 12271 VIN.
        • Chris H.
          • April 1, 2000
          • 837
          Also, unusual master cylinder/cover.
          • Jeff P.
            • 799
            350 HP valve covers, steel fan shroud. He must have wanted these instead of the painted covers and a fiberglass shroud.
            68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
            2014 Arctic White Z51 Vert. (Wifes)
            • Gene M.
              • April 1, 1985
              • 4232
              What's wrong with the steel fan shroud, it was used on early SB cars? It sealed well against the radiator for better cooling. The entire master cylinder is not Corvette unit at all as the casting ends would both be rounded. How does the alternator work without being plugged in?
              • Ralph S.
                • February 1, 1985
                • 935
                The belt tensioning brace on the alternator is on wrong.
                • Jeff P.
                  • 799
                  Gene,AC cars have a fiberglass shroud.
