Should I have my steering column restored? - NCRS Discussion Boards
  • Michael L.
    • December 15, 2006
    • 1413
    Guys,
    I'm considering whether or not to have my steering column on my '69 fully restored or whether I should just do a cosmetic facelift. I have never driven the car prior to beginning this restoration (long story) so I can't say anything about how the column was operating, except that the previous owner, who was a friend and is now deceased, never complained about it. I believe it is a standard column, not a tilt/telescopic or anything. Appreciate any input.
    Mike
    • 6956
    Re: Should I have my steering column restored?
    Mike I believe about the most common problems I see with steering columns is the key buzzer switch (plastic), and the directional turn signal return springs as the can break as they are spring steel. this is a easy test as the turning on and see if the lever returns when tuning wheel. I believe these parts are still available. and a OHM meter will test key buzzer switch, you just need to know which color the wire is.
