Screw ID - NCRS Discussion Boards
Screw ID
  • Brian M.
    • February 1, 1997
    • 1842
    Screw ID
    1967 H/L roll over switch fastener P/N 9419329
    and hood release pull fastener P/N 9417378
    • 43281
    Re: Screw ID
    Brian------
    GM #9419329----10-16 X 5/8", self tapping, zinc plated, pan head, phillips drive, 3/8" head OD
    I have no information on GM #9417378
    • Chuck G.
      • May 31, 1982
      • 2039
      Re: Screw ID
      Hi Joe,
      I'm getting conflicting information, and seeing conflicting information looking at dash/instrument cluster photos.
      I have only seen black phosphate/black oxide fasteners used under the dash. They are used to mount the vent cables, HL rollover switch, and even the steering wheel escutcheon.
      I've also seen black phosphate hex head screws mounting the vent cables, not pan phillips.
      I am NO 67 expert, and I know that 67 owners are a very knowledgeable group, dare I say "picky" when it comes to their cars, much like 63 owners.
      I don't have a 67 Judging Manual here at home, but I don't believe that this issue was addressed in the manual that the car owner has in his possession.
      Any thoughts?
      • Gary S.
        Super Moderator
        • February 1, 1984
        • 460
        Re: Screw ID
        Check this out:
        https://www.forums.ncrs.org/archive/...p/t-94352.html
        Avatar--My first ever vette, owned 3X since 1977, restored 1993-2024. Top Flight Award 9/14/24
        • Chuck G.
          • May 31, 1982
          • 2039
          Re: Screw ID
          Originally posted by Gary Seymour (7140)
          Thanks for that link, Gary. I missed that one when I did a search.
          What is on your car... and what has been on your previously owned 67's?
          Would they be.............. black phosphate, oval head, countersunk, phillips head screws holding both the steering wheel escutcheon and the vent pulls?
          How about the HL rollover switch? Would those be black phosphate, pan head, phillips head ?
          • David B.
            • March 1, 1980
            • 690
            Re: Screw ID
            GM # ---- 9417378 10-16 #8 head size 5/8 length phosphate coated **
            ** GM 4435-M code A
            • Gary S.
              Super Moderator
              • February 1, 1984
              • 460
              Re: Screw ID
              Chuck: I thought the standard for those was oval head on the headlight roll switch and counter sunk on the vent, hood release and steering escutcheon with all being phillips and all being black phosphate. Maybe someone has seen otherwise. Pictured below are two pretty original cars I once owned that I happened to take pictures of: red one is 65 vin #19XXX with original interior and paint and blue one is 67 air coupe vin #204XX that had all original interior and paint.
              • Chuck G.
                • May 31, 1982
                • 2039
                Re: Screw ID
                Great pictures, Gary. Thank you.
                That is sorta what I thought it should be... but I'm not a 67 guru.
                Chuck
                • Brian M.
                  • February 1, 1997
                  • 1842
                  Re: Screw ID
                  I noticed the H/L rollover switch mounted to the right on the 67, (with A/C) and the punch out removed in this location on the 65, interesting.
