c 4 L98 oil pressure - NCRS Discussion Boards
  • Edwin R.
    • April 16, 2008
    • 14
    Hello, My 1989 C4 drops oil pressure after drive around 24 miles. when cold gauge reads around 50 to 47 psi. I just replaced injectors and the Distributor also replaced oil pressure switch with and aftermarkerone.what could be the cause?
    • 43273
    Re: c 4 L98 oil pressure
    Edwin------
    You did not mention what the pressure drops to. That's important.
    Also, how many miles are on the car?
    • Edwin R.
      • April 16, 2008
      • 14
      Thanks for your reply, my car has 107,000 and the pressure steps down from 50 all the way to 4psi. When cruising around 1,100 and 1,200 keeps around 33psi.
        • 43273
        Edwin------
        4 PSI is somewhat low for idle oil pressure. However, the first thing you need to do is to install a test gauge on the engine to determine if the 4 PSI reading is accurate.
