1972 LT-1 numbers questions - NCRS Discussion Boards
  • Christian R.
    • November 11, 2016
    • 18
    Hello,
    I'm a new NCRS member, coming from Switzerland.
    I've seen in the past few days a LT-1 1972 with A/C.
    I've 2 questions regarding this car :
    1. the VIN number on birdcage seems to be strange..
    2. And more important to me, the stamping on engine is really not aligned. Could this a restamping? The VIN number on engine is correct.
    What do you think about these 2 things.
    Regards.
    Christian
  • Michael W.
    • April 1, 1997
    • 4290
    Re: 1972 LT-1 numbers questions
    Originally posted by Christian Rauber (62973)
    Hello,
    Welcome!
    The picture of the VIN tag is out of focus but I think it's safe to say that it's not an untouched, original GM tag. Possibly a State or Federally issued replacement?
    The engine pad stamps also do not appear to be factory original.
    What is the complete VIN of the car?
    • David R.
      • June 29, 2014
      • 183
      Christian -
      It's a little hard to read the VIN number in your photo, but 1972 Corvette numbers are relatively easy to decipher:
      1 (First Digit) - Make/Manufacturer. 1 - Chevrolet
      Z (Second Digit) - Model series. Z - Corvette
      37 (Third and Fourth Digits). 37- Corvette Coupe / 67 - Corvette Convertible
      K (Fifth Digit) - Engine type. K - Base Engine / L - LT1 / W - LS5
      2 (Sixth Digit) - Model Year. 2 - 1972
      S (Seventh Digit) - Vehicle Assembly Location. S - St. Louis, Missouri
      5XXXXX (Eighth thru Thirteenth Digits) - Plant Sequence Numbers.
      • The last six digits begin at 500001 and run thru 527004, accounting for all 27,004 Corvette Coupes/Convertibles built in 1972. Your car, if it is in fact a factory 1972 LT1, should have a VIN # beginning either 1Z37L2S5 if it is a coupe, or 1Z67L2S5 if it is a convertible. My 1972 LT-1, which I bought new, was 1Z67L2S514041.
      Good luck!
      • Mike E.
        • February 28, 1975
        • 5153
        It absolutely screams "bad restamp".
        • David R.
          • June 29, 2014
          • 183
          I agree, Mike - looks a little wonky for a factory stamp.
          • Christian R.
            • November 11, 2016
            • 18
            Thank you for your fast answer.
            I'm sorry, I forgot to write the numbers....it was very late Yesterday...for me in Europe ;-)
            VIN is : 1Z37 LS509989. I've found in Black Book that the date of building is between November and December 1971.
              • 15646
              Christian
              Welcome to NCRS and LT1 ownership.
              Open the drivers door. Attached to the body above the upper hinge should be a tag with the word CHEVROLET at the top. Following the word Chevrolet should be a letter with two numbers. In your case it may be something like E18 or E20. E = December, and the numbers are the day of the month.
              On the rear face of the driver's door should be a blue label that has the VIN number (1Z37LS509989) typed in black letters. On the upper right corner of the label will be "NOV 71". Let us know, with photographs if possible, what you find.
              I would suggest you order the 1970-72 Technical Information Manuam & Judging Guide (TIM&JG) from the NCRS store.
              National Corvette Restorers Society! 1968-82 NCRS Technical Information Manual & Judging Guides - Where does 48 years worth of detailed Corvette researchย byย the experts in the Corvette Hobbyย go? In these books.ย  The NEW 300+ page 1968-1969 Manual is NOW available!ย  The New 1980-82 Manual is NOW available! Prices are based on the base edition in all black and white, the expanded editions with color covers, and the expanded
              I am sure overseas shipping to Europe will be expensive (it is heavy), but it will have pictures of all that I have described above, and descriptions of what your Corvette should look like. I may be a little biased, but it is chuck full of Corvette information.
              • Joe R.
                • July 31, 1976
                • 4552
                What this deck screams is that somebody has sanded it smooth not knowing that it would be evaluated by every NCRS member in the world. It screams it was rusty and someone that doesn't care a (blank) about the NCRS rebuilt or restored this engine. IF someone was trying to fake this LT-1 they would have done a better job.
                JR
                • Patrick B.
                  • August 31, 1985
                  • 2018
                  The VIN number certainly proves the car is a real LT-1, and the stamp date is consistent with the car build date of late December. The pad appears to have been heavily sanded as Joe Ray observed, but the VIN stamp looks to be entirely correct. The V1210 part of the Flint stamp was gang stamped with fonts consistent with variations typical of Flint in the 70's. The only thing unusual is that all three characters of the CKY suffix appear to be individually hand stamped. We often see one or two characters hand stamped, but three would be uncommon. I agree with Joe that this is the original block but the heavy sanding just gives it a fakey appearance.
                  • Larry M.
                    • December 1, 1986
                    • 541
                    Christian,
                    Welcome to the NCRS, and LT-1 ownership.
                    Interesting that the engine pad, which shouldn't have paint, does; and the timing cover which should be painted, isn't.
                    Do you have any overall photos of the engine compartment?
                    Larry
                    • Christian R.
                      • November 11, 2016
                      • 18
                      Hello everybody,
                      Thank you for your answer. Unfortunately, I wasn't able to be on my PC Today....
                      The seller had today sent me some pictures of engine stamping and VIN numbers without paint.
                      Christian
                      • Christian R.
                        • November 11, 2016
                        • 18
                        I've joined you some pictures of the car during my visit of Thursday.
                        Any comments welcome ;-)
                        • Christian R.
                          • November 11, 2016
                          • 18
                          • Christian R.
                            • November 11, 2016
                            • 18
                            • Michael W.
                              • April 1, 1997
                              • 4290
                              Hello everybody,
                              Christian
                              Ah- that's better. I don't see any obvious problems. The engine bay pictures illustrate many replacement parts and a missing AIR system.
