1963 top radiator mounting bolts and washers - NCRS Discussion Boards
  • Jerry C.
    • November 1, 1995
    • 741
    What would the bolts and washers (flat and lock) be for this mounting? I have larger flat washers do to the larger opening in the bracket and TR bolt heads. Would this be right? Thanks in advance.
  • Alan D.
    • January 1, 2005
    • 2046
    Re: 1963 top radiator mounting bolts and washers
    Note sure as to which bolts are of interest, the ones (6) holding the shroud? Check 63AIM (Sect 11-13, sheet 8.00) that will give you the part number & we can go from there.
      • 6950
      Jerry, my 63 has the original bolt bolts at this location, Mine are WB head marks, and think that you are correct about the flats washers being a tad bid bigger. I have also seen WB1 head marks at the location on some other 63"s
      • John D.
        • December 1, 1979
        • 5507
        Trouble with aims is I don't believe it has info on the logos of the bolts.
        I believe my 63 has WBs Can't check now as its covered up big time for a long winter.
        • Joseph S.
          National Judging Chairman
          • March 1, 1985
          • 886
          I agree with the WB head marks. 5/16 X 1". I have also seen TR and RBS bolts here.
          • Rich P.
            • January 12, 2009
            • 1361
