1967 Fuel Gauge Issue - NCRS Discussion Boards
  • Ralph E.
    • February 1, 2002
    • 905
    Did the Toys 4 Tots Cruise this past weekend and now my fuel gauge is stuck at 3/4 full.
    How do I check the if the issue is the fuel gauge or sending unit?
  • Michael H.
    • December 1, 1987
    • 730
    Re: 1967 Fuel Gauge Issue
    Run a can of Seafoam or Techron thru your tank and see if that helps getting it working again.
    Mike
    • John D.
      • June 30, 1991
      • 875
      • Ralph E.
        • February 1, 2002
        • 905
        Thanks John, that is exactly what I needed.
        Not sure how I'm going to do the diagnostics all by myself. Appears a helper is needed.
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11334
          Ralph,
          By design, when power is removed from the meter movement(gauge), the last reading remains. Check for power at the rear of the gauge, and also for power at the Pink wire going to the sender. This feed from the IGN source is fused, so if the fuse is blown, this may be your fault.
          Rich
          • Ralph E.
            • February 1, 2002
            • 905
            Ralph,
            Rich
            Thanks, Not sure which fuse it could be? Have not checked for power yet?
              • 6950
              Ralph, a quick look in the fuel tank and make sure the float is not stuck, or sunk. you can also take a coat hanger and bend to hook the arm on sender and move float lever up and down to see if this creates some movement.
              • Ralph E.
                • February 1, 2002
                • 905
                Thanks Ed, I tried the coat hanger and lifted and lowered the float with out any change to the gauge.
                I removed the spare tire tub for access to the sender and removed all the wired connectors from the sender terminals. Checked the ohms between the pink terminal and ground and got ZERO, expected 100 ohms. Checked the ohms between the pink terminal and the tan terminal on the sender got about 60 ohms, but I cannot move the float at the same time I'm trying to read the ohmmeter. Need a helper. Was about to check the voltage at the pink wire connector with ignition on but got late and I'm cold.
                This is as far as I can go without a helper to move the float.
                • Richard M.
                  Super Moderator
                  • August 31, 1988
                  • 11334
                  Ralph, Gone all day just checking in. Ironically I was checking a electrical system on a '67 today after body drop yesterday.
                  The Top fuse marked "B/U LPS GAUGES" supplies power to the Fuel & Temp gauges, Fuel Sender, Park Brake Dash lamp, and BU lamps via the Pink wire. Do your Backup Lamps and Park Brake Dash lamp work? If they do the fuse is good but could be faulty later upstream for fuel gauge circuit.
                  With IGN on, check both sides of the fuse for 12V. The left side is the source, right side is the output to the circuits above. Pics of fuse panel in this recent Post. If good you should have 12v on the Fuel & Temp gauges Pink wires and Sender Pink wire.
                  The fuel sender wires pass through the rectangular Body Connector under the dash near the drivers side kick panel. It's a 12 place connector with only 10 positions used. Blk is ground, Pink is +12v, Tan is Sender terminal. Check the GND plug terminal at the sender as those rust easily.
                  Rich
