Re: 1963 Coupe Windshield Molding Clips
The biggest problem is that the ends of the upper molding are not catching on the clips at the very end of the windshield frame, closest to the sides. Do you know how close the clips need to be placed from the ends of the upper molding? Should a clip be placed in every sectional cut in the curve? If so, then more clips are needed then what was supplied by Paragon. The molding sat flush with the body during the dry fit. I'm thinking of pulling the windshield out for a third time, and starting over. (I cannot believe that I just said that.)
